Old 03-17-2015, 07:43 AM
BSUGeek BSUGeek is offline
environment map error help
Here is my code. I keep getting an error "Failed to load texture: 'space1_posx.jpg" I don't understand what's happening. When i run it I just get a grey screen but I'm trying to get an outer space sky.
#Add Sky
env = viz.add(viz.ENVIRONMENT_MAP,'space1.jpg')
sky = viz.add('skydome.dlc')
sky.texture(env)
Old 03-17-2015, 10:01 AM
The tutorial you are following uses a series of textures to produce the panoramic object, one for each orientation, a cube map.
Is your sky a cube map or just one texture you are trying to use as a cube map?
Old 03-17-2015, 10:10 AM
I believe it's just 1 texture. is there a way to make it a cube map?
Old 03-20-2015, 04:22 AM
I still don't understand the error I'm receiving... Can anyone help?
Old 03-20-2015, 10:24 PM
The viz.addEnvironmentMap command requires 6 textures. If you supply a filename that is a single texture you'll get an error. If you search for 'cubemap' and 'skybox' online you'll get an idea of what's required by this command. Also, the panorama demo in the Vizard help uses a cubemap. There maybe sites where you can download cubemaps that would work for your application.
random walk in piazza environment maya Vizard 7 01-15-2014 04:58 AM
create environment anurag sohane Vizard 0 01-12-2013 10:17 AM
Multi User Environment moneim230 Vizard 5 05-17-2011 05:56 PM
Open Position: Virtual Environment Programmer aarset Announcements 0 05-31-2009 07:23 AM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 08:21 AM
