Old 03-11-2015, 06:52 AM
g.vannan g.vannan is offline
Post Wii nunchuck connection problem
I connected wii mote and able to make walkthrough in cave but not able to connect nunchuck....need suggestion $$$
is any possible way to get acceleration value of wii mote?
Old 03-11-2015, 07:46 AM
Does the following show the nunchuk is connected?
#Add wiimote extension
wii = viz.add('wiimote.dle')
#Connect to first available wiimote
wiimote = wii.addWiimote()
#Rumble wiimote for 0.5 seconds when nunchuk is connected
def onConnect(e):
	if e.extension == wii.EXT_NUNCHUK:
		print 'nunchuk connected'
		e.object.setRumble(True,0.5)
viz.callback(wii.EXT_CONNECT_EVENT,onConnect)
You can get the acceleration. The wiimote plug-in page documents all the available commands.
Old 03-15-2015, 11:17 PM
Yes ,code is working
How to connect
Nunchuck joystick
Old 03-16-2015, 06:42 AM
Try the following:
nunchuk = wiimote.nunchuk
def printNunchukPosition():
	print nunchuk.getPosition()
vizact.ontimer(0,printNunchukPosition)
Oculus Rift connection problem mshukun Vizard 1 10-01-2014 12:15 PM
PPT Mocap and Motion Builder Connection Problem hxphan Precision Position Tracker (PPT) 3 02-22-2011 11:01 AM
Vizard problem mizutani_jun Vizard 4 01-09-2011 03:39 PM
Immersion Cyberglove connection problem gwfassociates Vizard 1 05-17-2009 03:29 PM
