Old 01-22-2015, 02:05 AM
armo armo is offline
check user input using vizinfo panel
Dear all
I am running an experiment with a 3x2 design, so that I have two variables, one with three levels and the other one with two.
Before the experiment starts, the experimenter has to choose what sequence of two levels, each from one of the two variables, have to be presented, but I would like to create a mechanism that controls if the input sequence has already been chosen. Specifically, I posed these conditions:
- if the sequence of variables has not already been chosen, the execution flow keeps going on
- if the sequence of variables has already been chosen but the experiment wants to go on anyway, the output data are renamed to prevent overwriting.
- if the sequence of variables has already been chosen and the experimenter wants to choose another sequence, turns back to the vizinfo panel.
The first two conditions work, but the third doesn't. Specifically, the user can choose another sequence but when he hits again the run button nothing happens and so the experiment doesn't go on. Could anyone tell me where I did wrong in my code?
best regards,
armo
import vizinfo
class Experiment:
	def __init__(self,title):
		self.title = title
# create a class object with the current experiment data
current_exp = Experiment('current experiment')
class ExperimentalSetting:
	def __init__(self, var1=None, var2=None):
		self.var1 = var1
		self.var2 = var2
class ExperimentalSession:
	def __init__(self, phase=None, number=None):
		self.phase = phase
		self.number = number
		self.settings = ExperimentalSetting()
	def __repr__(self):
		return self.phase + ' ' + str(self.number)
# create a class object with the current session data
current_session = ExperimentalSession()
def get_session_info():
	global phase
	global current_session
	global current_RT_file
	global current_ACC_file
	import os
	def check_existing_file(file_name, extension):
		'''checks if a file already exists'''
		if	os.path.exists( file_name + extension ):
			print 'file already exists...'
			return True
		else: return False
	def add_suffix(f):
		'''adds a suffix to a file.
		Used when a file already exists'''
		copy_suffix = 'Copy'
		f = f + ' - ' +  copy_suffix
		return f
	def rename_existing_file(file_name, extension):
		'''if a file already exists, rename it with a suffix extension'''
		if	check_existing_file(file_name, extension):
			checked_fileName = add_suffix(file_name) + extension
		else: checked_fileName = file_name + extension
		return checked_fileName
	current_RT_file	= None
	current_ACC_file = None
	isEqual = False
	while not isEqual:
		print 'displaying vizinfo box'
		#Add the vizinfo box
		infoBox = vizinfo.add('')
		infoBox.scale(1.5,1.5)
		infoBox.translate( 0.85, 0.95 )
		infoBox.title('Experiment Info: ' + current_exp.title)
		#Add the GUI elements to the box
		phaseTrainingBox = infoBox.add(viz.RADIO,1,'Training')
		phaseExperimentBox = infoBox.add(viz.RADIO,1,'Experiment')
		variable1_A_Box = infoBox.add(viz.RADIO,2,'A')
		variable1_B_Box = infoBox.add(viz.RADIO,2,'B')
		variable1_C_Box = infoBox.add(viz.RADIO,2,'C')
		variable2_1_Box = infoBox.add(viz.RADIO,3,'1')
		variable2_2_Box = infoBox.add(viz.RADIO,3,'2')
		runButton = infoBox.add(viz.BUTTON,'Run')
		# waits for pressing the runbutton to go forward
		yield viztask.waitButtonUp(runButton)
		# get the current session settings
		if phaseTrainingBox.get() == viz.DOWN:
			current_session.phase = 'Training'
		elif phaseExperimentBox.get() == viz.DOWN:
			current_session.phase = 'Experiment'
		if variable1_A_Box.get() == viz.DOWN:
			current_session.settings.var1 = 'A'
		elif variable1_B_Box.get() == viz.DOWN:
			current_session.settings.var1 = 'B'
		elif variable1_C_Box.get() == viz.DOWN:
		if variable2_1_Box.get() == viz.DOWN:
			current_session.settings.var2 = '1'
		elif variable2_2_Box.get() == viz.DOWN:
			current_session.settings.var2 = '2'
		current_file_labels = [
		current_session.phase,
		current_session.settings.var1,
		current_session.settings.var2,
		# create two files object with the experiment RT and ACC data
		RT_folder = 'data/RT/'
		ACC_folder = 'data/ACC/'
		current_RT_file_name = RT_folder + '_'.join(current_file_labels) + '_RT'
		current_ACC_file_name = ACC_folder +  '_'.join(current_file_labels) + '_ACC'
		print current_RT_file_name
		if check_existing_file(current_RT_file_name, '.txt') and check_existing_file(current_ACC_file_name, '.txt'):
			answer = viz.ask('this sequence has already been chosen. Continue?')
			if answer:
				print 'chose to continue and rename file'
				current_RT_file = open( rename_existing_file(current_RT_file_name, '.txt'),'w')
				current_ACC_file = open( rename_existing_file(current_ACC_file_name, '.txt'),'w')
				isEqual = True
				print 'chose not to continue'
				return
			print 'the file names don\'t already exist'
			current_RT_file = open( current_RT_file_name + '.txt','w')
			current_ACC_file = open( current_ACC_file_name + '.txt','w')
			break
	infoBox.remove()
	print 'current settings:', [x for x in current_file_labels]
def experimental_flow():
	yield get_session_info()
import viztask
viztask.schedule(experimental_flow)
In there a way in Vizconnect to allow user to select between different input devices JB_HP_Viz Vizard 2 11-05-2014 12:40 PM
User keyboard input without halting the program Zhi Vizard 2 06-23-2011 12:53 PM
Controlling User Input ohad Vizard 1 03-15-2010 05:16 PM
User Input Hodge1620 Vizard 2 11-17-2005 06:58 AM
user input problem Jerry Vizard 1 11-16-2005 03:15 PM
