Old 11-24-2014, 10:16 AM
BSUGeek BSUGeek is offline
Question Convert Screen Capture to base64
I was wondering how do you convert a screen capture of the running scene to base64 and put the base64 data into a file?
Old 11-25-2014, 09:01 AM
Here is a sample script that will save the raw image data of the screen to a base64 encoded file when the spacebar is pressed:
import viztask
import base64
model = viz.addChild('maze.osgb')
def SaveScreenTask():
	while True:
		# Wait for key press
		# Capture screen to texture
		texture = viz.addBlankTexture([1,1])
		viz.window.screenCapture(texture)
		# Wait a frame for image to be captured
		yield viztask.waitFrame(1)
		# Save raw texture data to base64 encoded buffer
		data = base64.b64encode(texture.saveToBuffer('<raw>'))
		# Save data to file
		with open('screen_data', 'wb') as f:
			f.write(data)
		# Remove texture
		texture.remove()
viztask.schedule( SaveScreenTask() )
screen capture of sub window rlh001 Vizard 1 07-22-2013 03:59 PM
Screen Size and Scaling javadi Vizard 2 04-02-2013 05:56 PM
Attach a TexQuad to pit.osgb screen Ducky Vizard 1 01-17-2013 02:57 PM
screen capture from all cluster computers? dtidrow Vizard 1 09-16-2009 10:25 AM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
