Cave
Hello everyone,
I've tried to develop for the CAVE environment, but I'm having any troubles to sync all images... Is there a plug-in that I can use? |
Hi Alex,
Are you doing it from a single computer? If not then you will need to use Vizard's cluster system which will require Enterprise license. There also some information that you can take a look and try it by yourself first. http://docs.worldviz.com/vizard/Vizcave.htm http://docs.worldviz.com/vizard/vizc...le_machine.htm http://docs.worldviz.com/vizard/vizc..._clustered.htm Best, Kevin |
I'm doing it from a single computer, but after I'll do from a Cluster.
Similar Threads | ||||
Cave Collision problem | TopazFrost | Vizard | 2 | 02-13-2014 02:34 PM |
orthographic projection in a head-tracked cave environment | michaelrepucci | Vizard | 5 | 12-14-2011 10:29 AM |
[New here] Cave joy navigation | esuna114 | Vizard | 2 | 06-11-2010 04:36 PM |
Flipped floor in a CAVE | shivanangel | Vizard | 1 | 03-10-2010 10:12 AM |
CAVE, navigation, tracked wand, coordinate systems | JimC | Vizard | 6 | 10-09-2009 12:43 PM |
