Old 08-15-2014, 08:27 AM
Billy501 Billy501 is offline
Arrington Eye tracker
Dear Experts
I'm wondering if anyone can clarify the data that the Arrington Plug-in is picking up in Vizard. I'm using the code below and I get three outputs which I presumes were xposition yposition and velocity (although I can seem to find any confirmation for this) - however these values don't seem to match is being shown in viewpoint. e.g I get
[0.44207999110221863, 0.4781699776649475, 0.0] in vizard
and Viewpoint is showing ~3 and 4 for x and y positions.
Thank you all for you time.
from ctypes import * # eyetrackka
import os
import sys
sys.path.append('C:/ViewPoint 2.9.2.5')
sys.path.append('C:/Program Files (x86)/WorldViz/Vizard4/plug-ins')
vpxDll = 'C:\ViewPoint 2.9.2.5\VPX_InterApp.dll'
if ( not os.access(vpxDll,os.F_OK) ):
	print("WARNING: Invalid vpxDll path")
cdll.LoadLibrary( vpxDll )
vpx = CDLL( vpxDll )
#Create arrington extension
arrington = viz.add('arrington.dle')
#Connect to eye tracker
tracker = arrington.addEyeTracker()
#Print smoothed gaze position (default)
print tracker.getPosition()
Old 08-15-2014, 02:13 PM
The 3 outputs are x,y,z although this tracker does not provide z data so the last value is 0. The gaze position is normalized from 0-1, relative to the lower left corner of the screen.
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 09:52 AM
Integrated orientation tracker in zSight HMD Zhi Vizard 2 06-06-2012 08:29 AM
Arrington Research Eye Tracker hankiwan Vizard 0 09-09-2009 06:48 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
Can Vizard interact with the Arrington eye tracker? Deltcho Vizard 1 09-18-2007 02:38 PM
