Old 02-17-2014, 02:32 PM
kmkm kmkm is offline
Proximity Sensor Problem
Hi there,
I'm trying to use a proximity sensor to change the color of a piece of text when the viewpoint collides with a specific node. I've been following the tutorial but I can't figure out why this isn't working. Please help!
viz.setMultiSample(4)
viz.MainWindow.fov(60)
#viz.setLogFile('Task-CP1.log')
#for i in [5]:
import sid
import time
import math
import random
import vizinfo
import vizmat
import viztask
#import vizjoy
import vizcam
import vizshape
import vizproximity
#def parameters():
#global experiment_data
global sky
global ground
global bigground
global grass
global skybox
#blank_screen.visible( viz.OFF )
sky = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
skybox = viz.add('skydome.dlc')
skybox.texture(sky)
ground = viz.add('randground.wrl') # Add ground
ground.collidePlane() # Make collideable plane
ground.setScale([10,10,10])
ground.disable(viz.INTERSECTION)
bigground = viz.Transform('whitenoise.tga')
bigground.setScale(5,5,5)
ground.texmat(bigground)
grass = viz.addTexture('whitenoise.tga')
viz.MainView.setPosition([50, 1.5, -20])
viz.MainView.setEuler([-9,0,0])
viz.MainView.collision( viz.ON )
viz.MainView.stepsize(.02)
global reward1
reward1 = vizshape.addCube(size=2)
reward1.color(viz.WHITE)
reward1.setPosition([47,0,-10])
reward1.setEuler([0,0,0])
reward1.texture(viz.addTexture('money.jpg'))
global value1
value1 = viz.addText3D('$3')
value1.fontSize(1)
value1.color(viz.RED)
value1Link = viz.link(reward1, value1)
value1Link.postTrans( [-.8, 1, 0] )
global reward2
reward2 = vizshape.addCube(size=1.5)
reward2.color(viz.WHITE)
reward2.setPosition([53,0,5])
reward2.setEuler([0,0,0])
reward2.texture(viz.addTexture('money.jpg'))
global value2
value2 = viz.addText3D('$12')
value2.resolution(2)
value2.fontSize(1)
value2.color(viz.RED)
#value2.center(65,1,5)
value2Link = viz.link(reward2, value2)
value2Link.postTrans( [-.8, 1, 0] )
global reward1Sensor
global reward2Sensor
reward1Sensor = vizproximity.Sensor(vizproximity.Box([5,2,5],center=[0,0,0]),source=reward1)
reward2Sensor = vizproximity.Sensor(vizproximity.Box([5,2,5],center=[0,0,0]),source=reward2)
global target
target = vizproximity.Target(viz.MainView)
#Create proximity manager
global manager
#Add destination sensors to manager
manager.addSensor(reward1Sensor)
manager.addSensor(reward2Sensor)
manager.addTarget(target)
vizact.onkeydown('d',manager.setDebug,viz.TOGGLE)
global choseReward1
choseReward1 = False
global choseReward2
choseReward2 = False
def EnterProximity(e):
if e.sensor == reward1Sensor:
value1.color(viz.GREEN)
choseReward1 = True
print 'reward: 1'
elif e.sensor == reward2Sensor:
value2.color(viz.GREEN)
choseReward2 = True
print 'reward: 2'
manager.onEnter(None,EnterProximity)>
Old 02-20-2014, 05:10 AM
Please post example code that reproduces the issue, is simplified as much as possible, and can be run directly without modification. That will make it much easier for others to help troubleshoot. Also, when posting code, use the code tags to preserve indentation.
Old 02-21-2014, 06:00 AM
The solution: simplified and readable (thanks to the code tags). Next time, posting with code tags makes it much easier to debug/troubleshoot as Jeff mentioned.
import vizshape
import vizproximity
ground = viz.add('ground.osgb')
global reward1
reward1 = vizshape.addCube(size=.5)
reward1.setPosition([1,2,1])
global value1
value1.fontSize(1)
global reward2
reward2 = vizshape.addCube(size=.5)
reward2.setPosition([-1,2,1])
global value2
value2.fontSize(1)
reward1Sensor = vizproximity.Sensor(vizproximity.Box(reward1.getScale(),center=[0,0,0]),reward1)
reward2Sensor = vizproximity.Sensor(vizproximity.Box(reward2.getScale(),center=[0,0,0]),reward2)
global manager
global target
global choseReward1
global choseReward2
		choseReward1 = True
		print 'reward: 1'
		choseReward2 = True
		print 'reward: 2'
Old 03-04-2014, 11:54 AM
Thank you! Sorry about the code tags.
proximity sensor
CompositeShape proximity sensor mhtong Vizard 1 09-24-2012 11:18 AM
Phase Space and Proximity Sensors snovob93 Vizard 3 06-13-2012 12:32 PM
Outputting modules just alex Vizard 0 02-16-2010 11:03 AM
triggering actions on proximity exhale Vizard 3 03-14-2005 02:26 AM
