Old 02-17-2014, 07:13 AM
rmcconnell11 rmcconnell11 is offline
joints/spin objects
Hi guys,
Currently working on a large fixture that has quite a few movable objects, which is not so great in terms of work for me.
Anyway, I need to the objects to move in and out when selected and I just can't seem to get it set up so that the objects are moving from the right point. I.e. the center point. I need to be able to either set a new centre point or perhaps links the point to a fixed point...?!? Any ideas?
I will post the code I've been using to do this later along with images of the scene graph. If I was able to set a new centre point that would be great, but under each part I have hundreds of nodes that make up the entire movable part, so it's a but much too call all these and set a new centre point for each (also they have been exported from catia to work format so I alsohave to rename all the nodes).
Any ideas or thoughts people, please?
Getting position of a group of objects mape2k Vizard 2 10-31-2013 08:33 AM
static or dynamic objects shahramy Vizard 2 11-10-2010 12:32 AM
