Old 02-14-2014, 06:09 AM
AntoniaHamilton AntoniaHamilton is offline
avatar and her reflection
i'm trying to create a scene with two avatars who mirror each other (e.g. Anna raises her R hand, Betty raises her left hand, with no visible mirror). I've tried a variety of ways to copy Anna's bones or actions onto Betty, and can't get any to work.
The code below is what I *thought* should work - it premultiplies the full Position/Quaterion matrix for each bone by the appropriate transformation matrix. But it isn't giving me the right thing. The commented out version doesn't work either.
So I hope someone can help. Is this the right approach? Is there something silly wrong here? Or is there a different solution all together?
Antonia
import vizshape
import viztask #Needed to control the experiment structure.
import vizinput #Needed to allow the input of participant information.
import time #Needed to record the date and time.
import numpy as np
viz.setMultiSample(4)
viz.fov(60)
Anna = viz.addAvatar('vcc_female.cfg')
Anna.setPosition([0,0,-1])
Anna.setEuler([0,0,0])
Anna.state(15)
Betty = viz.addAvatar('vcc_female.cfg')
Betty.setPosition([0,0,1])
Betty.setEuler([0,0,0])
Betty.state(15)
AnnaBones = {bone.getName(): bone for bone in Anna.getBoneList()}#For every bone in Linda's bone list, gets its name and make a dictionary.
BettyBones = {bone.getName(): bone for bone in Betty.getBoneList()}#Does the same for Mike.
mode = viz.AVATAR_LOCAL #Vizard defaults to ABS_PARENT. Sets 'mode' so that when we move the avatars' bones, they move locally to each avatar.
def reflect():
[BettyBones[bone].lock() for bone in BettyBones] #Locks Betty's bones.
# work out position & quaterion of each bone
for boneName in BettyBones:
p = AnnaBones[boneName].getPosition(mode)
q = AnnaBones[boneName].getQuat(mode)
t = AnnaBones[boneName].getMatrix(mode)
print '----------------'
print mode
print p
print q
print t
# s = vizmat.Transform()
# s.makeScale(1,-1,1)
# t.preMult(s)
# print t
# BettyBones[boneName].setMatrix(t,mode)
orig = np.array([ [p[0], 0, 0, q[0]], [0, p[1], 0, q[1]], [0, 0, p[2], q[2]], [0, 0, 0, q[3]] ])
rmat = np.array([ [ 1, 0, 0, 0], [0, 1, 0, 0], [0, 0, -1, 0], [0, 0, 0, 1] ])
nnn = np.dot(rmat,orig) #pre-multiply the original by the transform
newp = np.array([ nnn[0,0], nnn[1,1], nnn[2,2] ])
newq = np.array([ nnn[0,3], nnn[1,3], nnn[2,3], nnn[3,3] ])
BettyBones[boneName].setPosition(newp.tolist(),mode)
BettyBones[boneName].setQuat(newq.tolist(),mode)
def run_test():
vizact.ontimer(0, reflect)
viztask.schedule(run_test)
Old 02-21-2014, 01:58 AM
Hi Antonia,
I have been struggling with this problem for a while as well, and found the solution (at least using Euler rotations). To mirror the movements of another avatar, you need to apply the rotation of the left arm (for example) to the right arm AND you need to inverse the yaw & roll of that rotation. The pitch remains unchanged, because when you raise your arm in front of a mirror, your mirror image will also raise its arm. Furthermore, you don't need the position of the bones, the position of each bone is determined by the rotations of the 'motherbone'. I have updated your code, and this should do exactly what you are looking for, for any avatar with identical names for the left and right side bones (except for a unique left/right identifier).
On a side note, I am trying to understand matrix transformations using quaternions instead of using euler rotations (although I understand euler rotations, and I don't understand quaternions yet). So if you can tweak the code using matrix transformations, I'm all eyes !
Frank
import vizshape
import numpy as np
viz.fov(60)
UNIQUE_ID_LEFT_BONES = ' L '
UNIQUE_ID_RIGHT_BONES = ' R '
Anna.state(15)
Betty.setEuler([180,0,0])
#Betty.state(15)
def reflect():
	for AnnaBone in AnnaBones:
		if UNIQUE_ID_LEFT_BONES in AnnaBone or UNIQUE_ID_RIGHT_BONES in AnnaBone:
			copyboneName = AnnaBone
			if UNIQUE_ID_LEFT_BONES in AnnaBone:
				BettyBone = copyboneName.replace(UNIQUE_ID_LEFT_BONES, UNIQUE_ID_RIGHT_BONES)
			elif UNIQUE_ID_RIGHT_BONES in AnnaBone:
				BettyBone = copyboneName.replace(UNIQUE_ID_RIGHT_BONES, UNIQUE_ID_LEFT_BONES)
			BettyBone = AnnaBone
		eulerAnna = AnnaBones[AnnaBone].getEuler(mode)
		print 'Annabone', AnnaBone
		print 'Bettybone', BettyBone
		eulerBetty = eulerAnna
		eulerBetty[0] = eulerBetty[0] * -1
		eulerBetty[2] = eulerBetty[2] * - 1
		BettyBones[BettyBone].setEuler(eulerBetty, mode)
def run_test():
Old 02-21-2014, 02:14 AM
I was partly wrong about the position of the bones. You don't need to mirror the position of every bone, but only the position of the pelvisbone. The code below should work with any avatar with a pelvisbone named 'Bip01 Pelvis' (so at least every Complete Character from Vizard). And, now the position of the avatar is also mirrored!
import vizshape
import numpy as np
viz.fov(60)
PELVIS_BONE_NAME = 'Bip01 Pelvis'
Anna.state(2)
#Betty.state(15)
def reflect():
		posAnna = AnnaBones[PELVIS_BONE_NAME].getPosition(mode)
		eulerBetty[2] = eulerBetty[2] * -1
		posBetty = posAnna
		posBetty[0] = posBetty[0] * -1
		BettyBones[PELVIS_BONE_NAME].setPosition(posBetty, mode)
def run_test():
Old 02-21-2014, 02:52 AM
Thank you, that is very helpful.
