Old 11-23-2013, 09:35 AM
maya maya is offline
Exclamation multi user environment tutorial
hi,
I have been exploring the multi user tutorial in the reference.
I was trying to control the movement of the avatar (selected object from the object list) using keyboard. I have the code for the movement, but I didn't know how to do it.
this is the code for movement:
import viztask
import vizmat
#avatarRoot = viz.addGroup()
avatarRoot = viz.add('marker.wrl')
cameraLookAtNode = viz.addGroup(parent=avatarRoot, pos=[0, 1.5, 0])
avatar = viz.add('vcc_male.cfg', parent=avatarRoot)
viz.add('tut_ground.wrl')
def moveAvatar():
                          while True:
		#get user input
		newPos = vizmat.Vector()
		newPos.set([0,0,0])
		if viz.iskeydown('w'):
			#walk forward
			newPos = newPos + [0, 0, 1]
		if viz.iskeydown('s'):
			newPos = newPos + [0, 0, -1]
		if viz.iskeydown('a'):
			newPos = newPos + [-1, 0, 0]
		if viz.iskeydown('d'):
			newPos = newPos + [1, 0, 0]
		isJumping = False
		isAttacking = False
		if viz.iskeydown(' '):
			#jump
			isJumping = True
		elif viz.iskeydown('v'):
			isAttacking = True
		if isAttacking:
			avatar.state(6)
			yield viztask.waitTime( 1.5 )
		if newPos.length() > 0 or isJumping:
			if newPos.length() == 0:
				#jumping but no direction key, use current heading
				t = vizmat.Transform()
				t.setTrans([0, 0, 1.8])
				t.postEuler(avatar.getEuler()[0],0,0)
				newPos = vizmat.Vector( t.getTrans() )
			newYaw = vizmat.AngleToPoint(0, 0, newPos[0], newPos[2])
			avatar.setEuler(newYaw, 0, 0)
			if not isJumping:
				#just walking
				cameraEuler = viz.MainView.getEuler()
				avatarRoot.setEuler(cameraEuler[0], 0, 0)
				newPos = newPos * viz.getFrameElapsed()
				avatarRoot.setPosition(newPos, viz.REL_LOCAL)
				avatar.state(2)
				#jumping
				avatar.state(7)
				yield viztask.waitTime( avatar.getDuration(7)+.01 )
				#compute jump direction
				newJumpPos = vizmat.Transform()
				newJumpPos.setTrans([0, 0, 1.8])
				newJumpPos.postEuler(avatar.getEuler(viz.ABS_GLOBAL)[0], 0, 0)
				avatarRoot.setPosition(newJumpPos.getTrans(), viz.REL_GLOBAL)
		if not (viz.iskeydown(' ') or viz.iskeydown('w') or viz.iskeydown('s') or viz.iskeydown('a') or viz.iskeydown('d') ):
			avatar.state(1)
		yield None
viztask.schedule(moveAvatar())
import vizcam
camera = vizcam.PivotNavigate()
camera.setDistance(5)
def moveCamera():
	while True:
		lookAtPos = avatar.getBone('Bip01 Pelvis').getPosition(viz.ABS_GLOBAL)
		lookAtPos[1] = lookAtPos[1] + .5
		camera.setCenter(lookAtPos)
		camera.updateCenter()
		yield None
viztask.schedule(moveCamera())
my questions are:
1. in the moveAvatar function, the position of the avatar is saved in a variable newPos. what part of the multi user tutorial sets the selected object position?
2. how can I change the position of the selected object in the multi user tutorial
multi user environment code:
objectList = ['duck.wrl','logo.wrl','vcc_male.cfg','vcc_female.cfg']
obj_choice=vizinput.choose('Connected. Select your character',objectList)
def sendUpdate():
     ori= viz.MainView.getEuler()
     pos = viz.MainView.getPosition()
     viznet.client.sendAll(UPDATE,client=viz.getComputerName(),object=obj_choice,pos=pos,ori=ori)
 vizact.ontimer(.05,sendUpdate)
multi user maya Vizard 1 11-18-2013 10:31 AM
Multi User Environment moneim230 Vizard 5 05-17-2011 06:56 PM
begginer tutorial shader? Darkmax Vizard 1 04-15-2010 05:26 PM
Controlling User Input ohad Vizard 1 03-15-2010 06:16 PM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 09:21 AM
