Old 11-21-2013, 08:27 AM
ChrisMa ChrisMa is offline
HeadTracking Rotation does not match
Hello everybody,
I really tried hard. But I don't get the Rotation of my Head right. The positional tracking works as I wanted it. Is swapQuat the right command for it? For example, if i roll the Headtarget the view pitches upwards. I don't understand the positions in the swapQuat. 1,2,3 means Rotation around the x,y,z achses from my tracking Device, right? My Tracking Target has the z-axis in viewing direction, y to the sky and x to the left.
The Position in the matrix coresponds to the axis of my mainview. This is Z in the direction of my view and x to the right and y in the sky, right?
head.swapPos([-1,3,-2])
head.swapQuat([-1,3,-2,4])
HeadLink=viz.link(head, viz.MainView)
HeadLink.preEuler([0,0,270])
I just dont get it what to do. Can you help?
Thanks a lot for a quick reply!
Old 11-21-2013, 04:34 PM
What tracking system are you using? The following code will do a right-to-left conversion:
#Negate Z value of position
headTracker.swapPos([1,2,-3])
#Negate X,Y value of quaternion
headTracker.swapQuat([-1,-2,3,4])
Old 11-22-2013, 01:36 AM
Hi Jeff,
Vicon Tracker.
Old 11-22-2013, 04:25 AM
I really don't understand it. After two ours of trying I found this as a working solution.
head.swapQuat([-1,-3,-2,4])
The Z Value of the Head Target is pointing to the sky, the y-axis in viewwing direction and the x Axis to the right side of the user.
I would really appreciate if you could give me some Input on the swapQuat funkction.
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 12:06 PM
set bone rotation - cal3d munteanu24d Vizard 0 03-23-2010 04:25 AM
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 08:39 AM
tracking head rotation orientation VAmanda Vizard 3 09-21-2005 04:57 PM
getting absolute rotation tavaksai Vizard 1 08-03-2004 01:40 PM
