Old 03-13-2013, 05:58 AM
mape2k mape2k is offline
Breaking while loops with timers
Hello Vizard-Team!
I have a small problem: I want to break a while loop either with a button press (works fine) or after a certain amount of time has expired. So far, I have not been able to manage it with timer functions. Is there another way? The code below shows my current status. The timer function is called correctly and expires correctly after 10s, but the global testTrig variable is not parsed and the while loop does not break.
Any thoughts? Thank you!
def test():
	global testTrig
	for k in range(len(presentSeq)):
		testTrig = 0
		while testTrig is 0:
			testTrig = viz.callback(viz.TIMER_EVENT,testExpired)
			viz.starttimer(0,10) # start timer with 10s
			yield viztask.waitAny([waitJoyButton]) 							# wait for joystick button
			testTrig = 1
		# do some more before next iteration...
def testExpired(num):
	global testTrig
	testTrig = 1
	print 'Expired!'
	return testTrig
Old 03-13-2013, 06:36 AM
Are you doing anything in your while loop other than waiting for time to pass or the waitJoyButton condition? If not, it seems you could replace the while loop with something like:
yield viztask.waitAny( [ waitJoyButton, viztask.waitTime(10) ] )
Old 03-14-2013, 07:52 AM
Works brilliantly and much more elegant than creating a time for it...
Control of timers vizmaster Vizard 6 08-22-2008 09:36 AM
killing vizact timers cade_mccall Vizard 1 04-18-2007 09:20 AM
timers and director function Jerry Vizard 1 06-22-2006 09:47 AM
multiple timers paulpars Vizard 4 06-02-2006 10:12 AM
