Old 03-01-2013, 02:13 AM
Adding morphs from FaceGen in peoplemaker
Hi all,
I'm trying to import the morphs that are produced by FaceGen to Vizard head. These morphs are .wrl files. When I use the option open -> import morphs in Peoplemaker, the standard option is to open a .vzf file. However, I want to import morphs for the current .vzf I opened in Peoplemaker. When I change the files of type to all files, and I select the .wrl file, nothing happens (e.g. no morph is imported to Peoplemaker).
Now, I think I have to create a .vzf of all the .wrl files I want to add morphs from. When I do file -> open -> open file and I select one of the .wrl morph files, then the morph is opened in Peoplemaker. When I save this face as a .vzf, open the original face, import the newly created morph, and use tools -> create morph target, I get the error 'Encountered geometric components with different number of vertices. Cannot extract morph targets.'. Can someone give some tips to get this working?
Old 03-06-2013, 10:39 AM
OK, solved the issue. Now my next question is: I have a blink left and a blink right morph. I would like the left eye and right eye to blink at the same time. Using the blinking code, I've tried this:
#Blink morph ID of avatar
BLINK_MORPH_LEFT = 0
BLINK_MORPH_RIGHT = 1
#Action that will animate blink closing
close_eye_left = vizact.morph(BLINK_MORPH_LEFT,1,0.1)
close_eye_right = vizact.morph(BLINK_MORPH_RIGHT,1,0.1)
#Action that will animate blink opening
open_eye_right = vizact.morph(BLINK_MORPH_RIGHT,0,0.1)
open_eye_left = vizact.morph(BLINK_MORPH_LEFT,0,0.1)
#Action that will wait 1-5 seconds
wait_blink = vizact.waittime(vizact.randfloat(1,5))
blinking_time_left = wait_blink
blinking_time_right = blinking_time_left
#Action that will blink indefinitely
blinkAction_left = vizact.sequence( blinking_time_left, close_eye_left, open_eye_left, viz.FOREVER )
blinkAction_right = vizact.sequence( blinking_time_right, close_eye_right, open_eye_right, viz.FOREVER )
#Add blink action to avatar
face.addAction(blinkAction_left,0)
face.addAction(blinkAction_right,1)
However, now the blinking of the left and right eye is not synchronized. I think that each time the blinkAction_left and blinkAction_right is called, a new value gets assigned to wait_blink. However, if I make wait_blink a fixed float, the blinking happens really fast (though in sync). If I increase the value of wait_blink, it does not increase the waiting time between blinks. How can I adapt this code to make blink morphs morph at the same (random) time?
Old 03-06-2013, 11:24 AM
Using vizact.parallel() seemed to be the solution. Face.addAction is used because I use a custom face. For anyone interested:
#Blink morph IDs of blinking
closing_eyes = vizact.parallel(close_eye_left, close_eye_right)
opening_eyes = vizact.parallel(open_eye_left, open_eye_right)
blinkAction = vizact.sequence( wait_blink, closing_eyes, opening_eyes, viz.FOREVER )
face.addAction(blinkAction,0)
Custom head with 3dmenow or facegen & peoplemaker Frank Verberne Vizard 4 01-17-2013 12:46 PM
Problems with imported Facegen head Don Vizard 1 11-04-2011 01:27 AM
Head morphs are very slow - some way to prefetch? Josh Vizard 0 03-09-2010 01:04 AM
PeopleMaker - creating morphs vjonshih Vizard 4 01-02-2005 04:30 PM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 10:30 AM
