Old 12-10-2012, 05:08 AM
new_horizon new_horizon is offline
Method of Limits Program
Hi All,
This is a programming questions really, opposed to a Vizard specific question.
I want to set up an experiment where I have a vehicle traveling at a choice of six speeds (ranging from 20 mph to 60 mph).
I'd like the program to pick each speed at random, but not use each speed on more than four occasions. So if 20 mph has been presented four times, I'd like the program to select one of the speeds that has not exceeded the "max trials" if you like?
Can anyone show me the best way of achieving this? I have it working but the code is very clunky and long winded.
Old 12-11-2012, 02:25 AM
sleiN13 sleiN13 is offline
You could just create a list with all speeds in it four times than randomize the order of the list and pop a new speed from it.
Old 12-11-2012, 03:02 AM
That is true, but the issue is how to ensure that the program does not select the same speed twice (e.g there will be four entries of 30mph...how can I get it effectively "cross" these entries out once they have been randomly selected once?
T
Old 12-11-2012, 03:04 AM
Sorry I've just re-read that. What I mean is if there are four entries for each speed, how can I remove them from the array once they have been used?
User keyboard input without halting the program Zhi Vizard 2 06-23-2011 12:53 PM
How can i import the code form a Java program to Vizard? alberto_redo Vizard 1 10-07-2010 12:18 PM
How do I run a destructor before the end of the program? EnvisMJ Vizard 3 12-14-2009 05:17 PM
Get position data in an own little program Researcher Precision Position Tracker (PPT) 2 02-01-2006 02:55 AM
Loading .3ds-Files without interrupting Program flow Stefan Vizard 10 06-08-2005 04:44 PM
