Old 08-30-2012, 02:02 PM
nabrahamson nabrahamson is offline
Axis Coordinates from Inspector
I am having a little trouble finding the axis relative to the global coordinate system of an object from within Vizard. When I get the handle for the object in question, and try to get the coordinates, I see that it should be perpendicular to the global axis.
screw.getAxisAngle(mode=viz.ABS_GLOBAL)
[-1.0, -0.0, 0.0, 90.0]
The information I am interested in finding is the angle of the straight line coordinate system relative to the global coordinate system as shown in the attached screenshot of inspector below. Is this the Normal angle of the object? It's obviously available in inspector, I'm just wracking my brain trying to figure out what it is in Vizard.
Old 08-31-2012, 03:34 PM
The axes in Inspector contains the accumulated transform of the selected node path. You can find the equivalent transform by calling:
xform = node.getMatrix(viz.ABS_GLOBAL,node='name')
Where name is the name of the selected node in Inspector for which you want to retrieve the axis transform from.
I just noticed that this command won't work if the name refers to a leaf (drawable) node. This will be fixed in the next release though.
Old 09-05-2012, 09:51 AM
That's exactly what I'm looking for. Thanks.
Old 09-07-2012, 07:50 AM
So to follow up, I've been able to reproduce the coordinate system in inspector. However, I am now trying to move that screw along one of the axis of that coordinate system by doing the following:
moveaction = vizact.moveTo(y_trans,time = 1.0, mode = viz.ABS_GLOBAL)
screw.addAction(moveaction)
The point y_trans refers to is the endpoint of the green axis in the attached photos. As you can see by the second photo, the screw does not get moved to the end of the green Axis. Is viz.ABS_GLOBAL the wrong mode to use with this command? Or am I just referring to the wrong coordinate system?
ID:	521   Click image for larger version
Old 09-07-2012, 10:56 AM
No, you will want to use the default viz.ABS_PARENT mode, since you want the screw to move along its local axes.
How are you getting a handle to the screw object in Vizard? Are you using the getChild command?
Old 09-10-2012, 06:17 AM
I am calling the <node3d>.getChildren() function from the parent object.
Old 09-11-2012, 08:53 AM
I'm not sure if it's clear on what I'm trying to do. The first attached picture contains two coordinate axis drawn on the screw. The first one replicates the coordinate system that is created in inspector with axis colored red, green and blue. The second coordinate system shares its origin with the first, but is drawn to represent the global x,y,z coordinate system.
The basis for the first coordinate system is from the matrix created from the command:
<node3d>.getMatrix(viz.ABS_GLOBAL, node='Inst-1430')
[ 0.000000, -0.004384, -0.008988, 0.000000,
  -0.000000, 0.008988, -0.004384, 0.000000,
  0.010000, 0.000000, 0.000000, 0.000000,
  -0.381762, -0.560596, -2.557960, 1.000000 ]
So the x-coordinate is drawn by creating a vector using the 4th and 1st row of this matrix and scaled (just so they are visible). And the y (elements 5-7 of the matrix) and z (elements 9-11 of the matrix) coordinates are created using a similar method.
[-0.381762 + 0.0,  -0.560596 + (-0.004384), -2.557960 + (-0.008988)]
So the point I used to create the y coordinate is called y_trans.
I made the assumption that using the command
moveaction = vizact.moveTo(y_trans, mode = viz.ABS_GLOBAL)
<node3d>.addAction(moveaction)
Would move the screw to the endpoint of the green axis. Instead, that command moves the screw to the position shown in the second attachment. Is this because the transformation matrix given by the getMatrix command is applied to the node before the translation of the moveTo command?
Here is the complete code I am using to draw those axis:
def draw_line(p, axis, color):
	viz.startLayer(viz.LINES)
	viz.lineWidth(3)
	viz.vertexColor(color)
	viz.vertex(p)
	viz.vertex(axis)
	viz.endLayer()
def debug_script():
	#Data is a helper class that creates a global object to share all of our object data between scripts
        part = Data.getData().parts_list[0]
       	global screw
	screw = part.getChildren()[0]
	point = [-0.381762, -0.560596, -2.557960]
	x_axis = [ 0.000000, -0.004384, -0.008988]
	y_axis = [  -0.000000, 0.008988, -0.004384]
	z_axis = [ -0.01, -0.00, 0.00]
	x_global = [1.0, 0.0, 0.0]
	y_global = [0.0, 1.0, 0.0]
	z_global = [0.0, 0.0, 1.0]
	global x_trans
	x_trans = [point[i] + x_axis[i]*30 for i in range(3)]
	global y_trans
	y_trans = [point[i] + y_axis[i]*30 for i in range(3)]
	global z_trans
	z_trans = [point[i] + z_axis[i]*30 for i in range(3)]
	draw_line(point, x_trans, [1,0,0])
	draw_line(point, y_trans, [0,1,0])
	draw_line(point, z_trans, [0,0,1])
	x_global_axis = [point[i] + x_global[i] for i in range(3)]
	y_global_axis = [point[i] + y_global[i] for i in range(3)]
	z_global_axis = [point[i] + z_global[i] for i in range(3)]
	draw_line(point, x_global_axis, [1,1,0])
	draw_line(point, y_global_axis, [1,0,1])
	draw_line(point, z_global_axis, [0,1,1])
ID:	524   Click image for larger version
Old 09-11-2012, 09:11 AM
There is not enough information for me to say what the problem is. My guess is you are applying the transformation at the wrong hierarchy in the scene. node.getChildren will not return anything unless you previously called node.getChild or parented a node to the object. So it's not clear to me exactly which node you are operating on.
Click on the screw you want to translate in Inspector, then post a screenshot of the node path bar at the top, showing the full hierarchy of the screw. This should provide me with enough information to post some sample code for you.
Old 09-11-2012, 11:38 AM
Here is the screen cap you requested.
Old 09-11-2012, 11:49 AM
Thanks. The following code should translate the screw object along its local Y-axis:
screw = model.insertGroupBelow('Inst-1430')
screw.setPosition([0,0.1,0])
This works by inserting a node below the Inst-1430 node. If you had called getChild on the node, it would have inserted a transform above the node, which would then translate the node in the incorrect reference frame.
Make sure you only call insertGroupBelow once per sub-node, since each call will insert a new node.
Old 09-11-2012, 12:32 PM
That appears to be what I am looking for. Thank you for your patience and help with this.
Old 09-24-2012, 02:03 PM
Quick question regarding the nodes created by the insertGroupBelow command. I'm finding that these nodes seem to be immutable. Is there a reason for that?
Old 09-24-2012, 02:20 PM
To clarify, I have a node n:
sub_n = n.insertGroupBelow(<nodename>)
So when I want to add an attribute to sub_n like:
sub_n.parentNode = n
I cannot access that parentNode attribute.
Old 09-25-2012, 08:16 AM
It's still not clear what the problem is. Are you getting a Python exception when trying to set an attribute? If so, what is the error? Can you post some sample code that reproduces the error?
The following code works correctly for me:
model = viz.addChild('gallery.osgb')
group = model.insertGroupBelow('gallery')
group.myattribute = 'some value'
print group.myattribute
Old 09-25-2012, 09:13 AM
Definitely. Sorry for lack of information.
The problem seems to be that when I call insertGroupBelow on a node, that group replaces the node.
So here is what I'm doing:
	sub_instance = p.insertGroupBelow(subnode)
	sub_instance.parentNode = p.instanceName
        ''' this copies defined properties from the parent node to the sub node '''
	CADParser.copyParams(p, sub_instance)
	sub_instance.inCollide = []
The meat of the copyParams code looks like this:
def copyParams(src,dst):
	dst.instanceNumber = src.instanceNumber
	dst.instanceName = src.instanceName
	dst.partNumber = src.partNumber
	dst.anarkParent = src
	src.anarkGroup = True
	dst.anarkGroup = True
	param_list = ["anarkFreeMovement"
				, "anarkTrans"
				, "anarkRotate"
				, "anarkRehomePos"
				, "anarkRehomeOri"
				, "anarkDependency"
				, "anarkColor"
				, "anarkAlpha"
				, "anarkBackface"
				, "anarkShader"
				, "anarkDescription"
				, "anarkImage"
				, "anarkModule"
				, "anarkLocal"
				, "anarkTool"
				, "layerSpacing"
				, "anarkRequires"
				, "anarkModRotate"
				, "anarkRev"
	for param in param_list:
		if hasattr(src, param):
			exec("dst." + param + " = src." + param)
			try:
				exec("del dst." + param)
			except:
				pass
	if hasattr(dst, "anarkColor"):
		src.color(dst.anarkColor)
	if hasattr(dst, "anarkShader"):
		if dst.anarkShader == "smoothmetal":
			reflect = viz.add('image2.jpg')
			dst.texture(reflect,'',1)
			dst.appearance(viz.TEXGEN,'',1)
	if hasattr(dst, "anarkRotate"):
		src.rotatingParent = dst
In another module, when I've got the handle on one of these groups created with the insertGroupBelow, I get an exception when trying to access a parameter like:
'''Only executed when this part has been marked as being an inserted group'''
print part.anarkParent
I get an exception saying that the attribute does not exist.
Old 09-25-2012, 09:46 AM
Because I can no longer edit my post,
Remove the code
			try:
			except:
				pass
From my previous post.
Old 09-25-2012, 10:53 AM
It is turning out to be that the part handle I thought was the group I created, is not the part I'm accessing in the other script.
I'm doing more digging to get the correct part handle.
Old 09-25-2012, 01:09 PM
And not having the correct part handle was indeed the case. Thanks again Farshizzo.
Old 10-24-2012, 12:32 PM
Re-opening the issue
I've come across some special cases here where we have parts that are modeled using multiple meshes. I would like to grab the handle of the highlighted part in the inspector picture, and move it along it's local coordinate axis. When I use the method of grabbing the two sub instances and move them the same distance along their coordinate axis, the behavior in the second attached picture is observed.
ID:	542   Click image for larger version
Old 11-05-2012, 01:27 PM
I tried re-creating this issue without all of my extra code libraries, and was unable to. When I dug further, I found that the parts were being moved multiple times at different levels of the hierarchy.
In short, this issue is resolved.
Haptic touch texture coordinates yth Vizard 0 06-02-2012 03:40 AM
How do coordinates in IS900 thransform into coordinates in vizard's world jacky Vizard 1 08-11-2011 10:44 AM
child-objects in VRML-file all have the same coordinates Sven Vizard 4 06-09-2010 02:07 AM
viz.vertex coordinates lilio Vizard 6 05-16-2009 04:36 PM
Object rotating around world axis, not own axis tacbob Vizard 1 02-15-2007 09:12 AM
