Old 06-18-2012, 01:41 AM
goro goro is offline
How can I apply physics to Donut or Ring?
In Vizard we have collide shapes for our physical objects
collideBox
collideSphere
collideCapsule
collideMesh
collidePlane
collideBox, collideSphere & collideCapsule can get affected by dynamic forces like gravity but collideMesh objects are unaffected by forces and can only provide a solid collision area for other objects. I want inner side of donut or ring too to have physical properties. Can you help me with the logic to get this thing done?
Old 06-27-2012, 01:32 PM
There is no built-in torus shape in the physics engine, but you can approximate one using multiple sphere shapes. Here is a sample script that simulates a torus using 18 spheres:
import math
import vizshape
viz.phys.enable()
ground = viz.addChild('ground.osgb')
ground.collidePlane()
RADIUS = 1.0
TUBE_RADIUS = 0.5
torus = vizshape.addTorus(radius=RADIUS,tubeRadius=TUBE_RADIUS)
for deg in range(0,360,20):
	x = math.sin(viz.radians(deg)) * RADIUS
	z = math.cos(viz.radians(deg)) * RADIUS
	torus.collideSphere(radius=TUBE_RADIUS,pos=(x,0,z))
ball = vizshape.addSphere(radius=0.6)
ball.collideSphere()
def Reset():
	torus.setPosition([0,2,10])
	ball.setPosition([0.6,5,10.6])
vizact.onkeydown('r',Reset)
Reset()
collide, donut, physical, physics, shape
Apply a texture to a submesh EnvisMJ Vizard 5 12-29-2011 10:34 AM
RE:Slide Joints and physics optimization nige777 Vizard 4 06-22-2009 04:21 PM
Physics and Haptics jalvarez Vizard 3 07-16-2008 03:03 PM
collision with physics enabled joeymax Vizard 2 04-17-2008 02:49 PM
Physics engine question adimov Vizard 2 07-22-2004 12:33 PM
