Old 09-28-2005, 05:35 PM
vsully vsully is offline
Send a message via AIM to vsully
.translate 'n' .goto
Trying to animate an object reseting to a position then moving to locatoin. Right now using a 'myfunc' director function to call a .translate and a .goto.
Problem is, repeated calls to viz.director(myfunc) results in the object moving farther and farther away.
.translates are absolute_world.
thoughts?
second thoughts, it works with simple scripts, but not with the 3dsound and texturing i'm trying. i've attached the portion of the code this deals with.
CAR_TRANSFORM = [1,1,1]
CAR_GOTO = 15
#Add mini
mini = viz.add('mini.osgx')
mini.translate(CAR_TRANSFORM, viz.ABSOLUTE_WORLD)
#Mini cooper textures
miniTextures = [viz.add('images/coopers01_chilired.jpg')]
def movecar():
	#texture car
	mini.texture(miniTextures[0],'default')
	#play sound
	mini.playsound('audio/vwbuggy.wav',viz.PLAY)
	dest = CAR_TRANSFORM
	dest[2] = dest[2] + CAR_GOTO
	mini.goto(dest, 2, viz.SPEED)
	vizact.waittime(3)
def stuff(key):
	viz.director(movecar)
viz.callback(viz.KEYUP_EVENT, stuff)
Old 09-28-2005, 08:55 PM
The problem is with the following line:
In python when you assign a list to a variable, it doesn't make a copy. So when you modify the z coordinate of the dest variable you are also modifying the CAR_TRANSFORM variable. Use the following code to make a copy of the list:
dest = CAR_TRANSFORM[:]
Old 09-28-2005, 08:59 PM
k thanks - i was thinking it might be something simple like that...
