Old 03-15-2012, 08:23 PM
dthomas dthomas is offline
Avatar Texture Problem
I'm using 3DSMax2012 to export 3 avatars from an avatar library into Cal3D. I had little trouble animating them and exporting the first (a single mesh model), but the other 2 don't show textures.
I tried applying the texture in vizard, but I don't know how to get the hair mesh texture to work (the body texture just applies a duplicate of itself to the hair also).
I couldn't find how to deal with meshes with several textures, or how to export "Multi/Sub-Object" materials. How do I export these into Cal3d format?
Old 03-17-2012, 10:59 AM
It might have been that the mesh had the same name as the skeleton (aside from the .cmf extension). After adding [0] and [1] to the materials I enabled fliptexture in the .cfg and everything seemed to export ok.
Old 03-20-2012, 12:20 PM
Maia Maia is offline
May I ask you which avatar library are you using ?
Cheers,
Maia
Old 12-23-2012, 10:52 PM
goro goro is offline
In any case if this thread is open then please let me know that is there any method available to get nodes from CAL3D avatar?
I want to apply shaders & texture to individual nodes of CAL3D Avatar. To get those nodes I wrote the following code.
viz.setMultiSample(4)
viz.fov(60)
female = viz.addAvatar('vcc_female.cfg')
female.setPosition([0,0,3])
female.setEuler([180,0,0])
female.state(12)
print 'Model contains the following scene graph nodes:'
for name in female.getNodeNames():
    print ' ',name
and I am getting this output
casual01_f_highpoly.CMFX
casual01_f_highpoly01.CMFX
I am not able to get the subnodes which I use to get in OSGB models.
Old 01-02-2013, 11:37 AM
You can specify the mesh name as the optional node parameter when applying the texture/shader. For example:
female.texture(tex,node='casual01_f_highpoly.CMFX')
3dsmax, avatar, cal3d, exporting
Avatar texture swaping sleiN13 Vizard 5 06-24-2011 01:48 AM
Avatar speaking problem Uttama_vizard Vizard 4 03-23-2009 12:29 PM
Skydome texture problem theuberk Vizard 2 01-18-2008 06:56 AM
Problem with letting an avatar face towards another avatar ghazanfar Vizard 2 03-21-2007 03:30 AM
avatar head texture issues rconrey Vizard 3 11-17-2004 05:05 PM
