I want to ask some program about vizard and 5DT
Now I have Vizard and 5DT dataglove, and i have read the ''5DT data glove basics''. But I want to make the virtual hand moves with sevral seconds dalay, not synchronous with my real hand. Can someone help me? Thanks. Best regards. |
? No one care?
This should be possible. You would have to look in hand.py to see how 5dt sensor data is mapped to the hand model. You would have to customize that to account for a delay.
OK. Thanks. And what should I do if I want to calibrate the data glove?
I want to use vizard(python) to show the data. But why it cannot? The code is here.
import viz import vizact import hand PORT_5DT_USB = 0 glove = viz.add('5dt.dls') data = glove.getData() print data But the data printed is only one line [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0] What should I do? |
OK. Now I have solved the third question myself. So what should I do with the calibration?
normally with my glove i don't have to calibrate it, i just connect it and it works, maybe in some case i get a strange behavior but i just close and open the hand several times but that's all.
how did you print the data out?
Tags |
5dt dataglove |
