Old 01-25-2012, 01:00 PM
pcatalano pcatalano is offline
setEuler argument/documentation confusion
The documentation for the setEuler function (and some other rotation/translation functions) is, at least to me, misleading with respect to its arguments.
The doc lists:
<viewpoint>.setEuler(
    [yaw,pitch,roll]
    mask = viz.HEAD_ORI     # Positional argument
    mode = viz.ABS_PARENT     # Positional argument
However, this doesn't produce the correct results. For example:
viz.MainView.setEuler([90, 0, 0], mode = viz.REL_LOCAL)
will not rotate 90 degrees relative to local. The mode argument doesn't make a difference when the function is called this way.
The only way to get the desired results is to call like this
viz.MainView.setEuler(90, 0, 0, mode = viz.REL_LOCAL)
or
viz.MainView.setEuler([90, 0, 0], viz.HEAD_ORI, viz.REL_LOCAL)
I imagine this is why there is a comment "positional arguments" next to mask and mode arguments in the documentation, but, at least for me, the documentation doesn't clearly indicate the correct way to call the function (and it's easy to incorrectly call it and not realize it).
setEuler method of Shadow module omidbrb Vizard 1 02-22-2010 09:35 AM
setEuler after Linking problem durf Vizard 1 06-05-2009 01:41 PM
Problem with getEuler and setEuler Sandro Holzer Vizard 6 10-21-2008 05:01 AM
quad buffered frame rate confusion michaelrepucci Vizard 11 09-17-2008 08:55 AM
confusion over vizcave and viewpoint michaelrepucci Vizard 3 08-01-2008 01:54 PM
