getVisible unexpected behaviour
I wanted to use the visibility of a object to execute (or not) certain code in a vizAction to my surprise all object returned getVisible() is True while I knew that the certain parent object where invisible. A simple test confirmed that child object don't return the correct visibility value
groupA = viz.addGroup() groupB = viz.addGroup(parent = groupA) groupA.visible(viz.OFF) print groupB.getVisible() >>> True |
This is by design. The node.getVisible() command returns the visible flag of the node. It does not take into account the visible flag of any parents.
You can use the node.getParents() command to determine the visibility state taking into account all parent nodes. Example: Code:
import viz import vizact viz.go() group1 = viz.addGroup() group2 = viz.addGroup(parent=group1) ball = viz.addChild('beachball.osgb',parent=group2,pos=(0,1.8,2)) label = viz.addText('',parent=viz.ORTHO,fontSize=50,pos=(10,10,0)) def isNodeActuallyVisible(node): if not node.getVisible(): return False parents = node.getParents() if parents: return any(isNodeActuallyVisible(p) for p in parents) return True def UpdateLabel(): if isNodeActuallyVisible(ball): label.message('visible') else: label.message('not visible') vizact.ontimer(0,UpdateLabel) vizact.onkeydown('1',group1.visible,viz.TOGGLE) vizact.onkeydown('2',group2.visible,viz.TOGGLE) vizact.onkeydown('3',ball.visible,viz.TOGGLE) |
Strange Ball Joint behaviour | mkmatlock | Vizard | 1 | 11-04-2010 04:49 PM |
Unexpected carriage return | vizmaster | Vizard | 3 | 01-23-2007 12:46 PM |
Tk with Vizard abnormal behaviour | Gilliard | Vizard | 2 | 08-04-2005 01:14 AM |
