Old 10-24-2011, 10:12 AM
fivel_lab fivel_lab is offline
getting position relative to an object
i'm running an experiment using vizard, and the experiment consists of having a balance board apparatus with a block placed at the boards center. the board starts to tilt at the start of a trial, and as it does so the block starts to slide accordingly. participants are tasked with keeping the board stable and the block within a target region that is located 1/4 of the board's length on the left side.
the board's color is black, as is the block's. the target region is denoted by a white block that has been added as a child to the board.
what i would like to do is have the block's color change to white whenever it is within the target region. problem is, i don't know how to obtain the block's position relative to the board, rather than the world without setting the block as a child of the board. any suggestions?
Old 10-24-2011, 06:28 PM
Why don't you want the block to be a child of the board?
If you are using world coordinates you could get the distance between the block position and the target position using the vizmat.Distance command. If it's within a certain then change it's color.
Old 10-26-2011, 01:45 PM
works, thanks =-)
as for why i didn't want the block to be a child of the board, whenever i had it set up that way, the ball wouldn't slide the way i wanted it to. again, not sure why...
Old 10-26-2011, 02:08 PM
ok, new issue...
the block slides off more often than i expected during my trial runs, so i'm thinking of including "bookends" on the ends of each side of the board.
        global bar
	bar = viz.add('box.wrl')
	bar.setScale([BARLENGTH, CUBESIZE,CUBESIZE])
	bar.setPosition(CENTERPOS)
	bar.color(viz.BLACK)
	barCollideShape = bar.collideBox()
	barCollideShape.setDensity(DENSITY)
	barCollideShape.setFriction(FRICTION)
        end1=bar.add('box.wrl')
	end1.setPosition((CENTERPOS[0]-.55, CENTERPOS[1]-4,     CENTERPOS[2]-5))
	end1.color(viz.WHITE)
	end1.setScale([.05,3,1])
	end1Collide = end1.collideBox()
	end1.disable(viz.DYNAMICS)
	end1Collide.setDensity(DENSITY)
when i use .disable(viz.DYNAMICS), the block slides right through the bookend, but without it, the bookend itself behaves crazily.
Old 11-02-2011, 07:24 PM
If you increase the scale value for the X dimension does it make a difference?
Get a user's current position from an object? cgibb Vizard 2 06-03-2009 05:47 PM
Randomising position of an object ptjt255 Vizard 11 10-23-2008 02:27 AM
Getting object position in screen coordinates v-Salik Vizard 1 10-19-2007 03:41 PM
