Old 08-30-2011, 03:40 AM
andrewjworz andrewjworz is offline
Collision detection with InfiniteTerrain Generator
I am wondering if there is anyway to activate collision detection with the infinite terrain generator (InfiniteTerrain.dlc). Given below is a simple example of code, and if you copy/paste and run it in vizard you will see that the ball falls straight through the infinite plane without colliding with it. Anyone Have any suggestions?
#Turn on the physics engine
viz.phys.enable()
viz.MainView.setPosition([0,180,0])
viz.MainView.setEuler( [0,40,0] )
#add sun-like directional light
l = viz.addLight()
l.position(0, 1, -.2, 0) #sets light direction
terrain = viz.add('InfiniteTerrain.dlc',1,'300',6,7,15000,0. 001)
grass = viz.addTexture('gb_noise.jpg')
terrain.texture(grass)
terrain.collideMesh()
ball = viz.add('ball.wrl')
ball.collideBox(density=5)
ball.setScale([50,50,50])
ball.setPosition([0,100,100])[/COLOR]
Old 08-30-2011, 04:13 AM
Also, I am trying to have the view point "walk" along the surface of the terrain generated by the InfiniteTerrain.dlc at a fixed height (let's say, the height of an avatar). I would like to move in the x and z directions with the arrows on the keyboard, while the viewpoint adjusts to the proper height about the terrain. Does anyone have any idea how to do this? Given below is the viewpoint controls that I have been using.
# Viewpoint keyboard controls
## Turn off built-in mouse navigation
#viz.mouse(viz.OFF)
## Hide mouse cursor
#viz.mouse.setVisible(False)
MOVE_SPEED = 19
TURN_SPEED = 60
male = viz.addAvatar( 'vcc_male.cfg' )
male.scale([10,10,10])
#male.collideCapsule()
viz.MainView.setPosition(0,terrainmaker.terrainfun c(0,0)+17,0)
viz.MainView.setEuler([0,0,0])
## Extract the main viewpoint
view = viz.MainView
## Make function which calls back for keyboard event
pos_init = view.getPosition()
def updatemale():
if viz.key.isDown('d'):
view.move([0,-MOVE_SPEED*viz.elapsed(),0],viz.BODY_ORI)
if viz.key.isDown('f'):
view.move([0,MOVE_SPEED*viz.elapsed(),0],viz.BODY_ORI)
if viz.key.isDown(viz.KEY_UP):
male.state(2)
view.move([0,0,MOVE_SPEED*viz.elapsed()],viz.BODY_ORI)
if viz.key.isDown(viz.KEY_RIGHT):
view.setEuler([TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
elif viz.key.isDown(viz.KEY_LEFT):
view.setEuler([-TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
elif viz.key.isDown(viz.KEY_DOWN):
male.state(2)
view.move([0,0,-MOVE_SPEED*viz.elapsed()],viz.BODY_ORI)
elif viz.key.isDown(viz.KEY_RIGHT):
male.state(2)
male.state(2)
male.state(2)
male.state(2)
# Attach the male to the viewpoint BODY_ORI
male.setPosition(view.getPosition())
male.setEuler(view.getEuler(viz.BODY_ORI))
male.setPosition([0,0,25],viz.REL_LOCAL) #[0.35,-1.7,-0.13]
Old 08-30-2011, 05:19 AM
nige777 nige777 is offline
Hi Andrew,
The walkTo function accepts an object (node) as the 'y' argument allowing the avatar to follow it precisely - as explained in this post:
http://forum.worldviz.com/showthread...ghlight=walkTo
Collision detection Moh200jo Vizard 1 01-27-2010 07:39 AM
Collision detection with specific models just alex Vizard 1 02-06-2009 11:02 AM
Collision Detection and Nearest Point to Probe xabbu Vizard 2 01-06-2009 03:01 AM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 04:47 AM
