Old 08-03-2011, 02:17 PM
AySz88 AySz88 is offline
Getting positional data from tracker
I have an application where a VRPN tracker is linked to an object, and then that link needs to be severed to have the physics simulation take over. (In this case, I'm "tossing" a ball using a HiBall 3000 stylus.)
From what I can tell, the tracker doesn't calculate this (right?), so I need to estimate the object's velocity from position data myself. What's the best way to grab position updates from the tracker in a callback-ish sort of way? I tried redefining the ball's setPosition method, but that doesn't seem to work. Should I define some sort of setter function at all?
Old 08-03-2011, 03:22 PM
You could register a callback function with vizact.ontimer to get the position on a specified interval.
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 04:49 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
updating positional data Saz Vizard 8 01-12-2009 04:23 AM
Obtaining Positional Data Plasma Vizard 40 04-04-2006 11:31 AM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
