Old 02-16-2011, 04:12 AM
chris_user chris_user is offline
animating the verticies, lines or polys of an object?
hello, I hope one of you guys can help.
I try to figure out if it is possible to animate the geometry of a placed object and connect it to the movement of another object?
thanks in advance, chris
Old 02-22-2011, 11:05 AM
Can you describe the animation you want in more detail?
Old 02-23-2011, 12:29 AM
hello jeff,
we need to attach some cables to a moving, rotating object on one side and on the other it remains in position. the movement is controlled by a button press.
thanks
chris
Old 02-23-2011, 03:26 PM
So the geometry of the moving, rotating object is changing as the cables move? Here's a link to an article that discusses animations using 3ds Max:
http://kb.worldviz.com/articles/1233
black lines with render to texture Darkmax Vizard 5 03-07-2011 11:23 AM
Making an object to appear after other object done animating jaylocco Vizard 2 07-13-2009 06:17 PM
