Old 02-07-2011, 04:56 PM
disbeat disbeat is offline
vizdlg Panel: Add and remove
I am developing an application with several scenes.
I created a dlg Panel, but I cannot attach it to a scene.
Also, I cannot remove it either.
How can I use the panel associated to a specific scene, and how can I remove it.
thanks
Old 02-07-2011, 07:02 PM
You can use the parent command to parent the panel to viz.SCREEN and specify the scene number. To remove a panel you can use the remove() command:
import vizdlg
panel = vizdlg.Panel(padding=15,border=False)
panel.addItem(viz.addText('Panel for scene 2'))
panel.background.alpha(0.6)
panel.background.color(viz.BLACK)
panel.parent(viz.SCREEN,scene=2)
panel.setPosition(0.4,0.6)
panel.setScale([2,2,2])
gallery = viz.addChild('gallery.ive')
court = viz.addChild('court.ive',scene=2)
vizact.onkeydown('1',viz.scene,1)
vizact.onkeydown('2',viz.scene,2)
vizact.onkeydown('3',panel.remove)
Old 02-08-2011, 12:44 PM
Thank you Jeff, it was very helpful.
May I ask why isn't those methods documented? Does the vizdlg Panel have a super class I am not aware of? Even so, I think that should be documented.
I leave you guys the suggestion
Once again, thank you very much!
