Old 12-02-2010, 08:57 AM
blessonisaac blessonisaac is offline
Intersense connection
Dear administrator,
I tried to connect two intersenses IS-900 series. One is with shutter glass and other one is wand. I am able to connect with the shutter glass intersense but not with the wand. I used the following scripts. Again when the intersense(shutter glass) is enabled the scene rotates automatically. How do I stop the rotation? I am using wireless but NOT COM1 and COM2.
isense = viz.add('intersense.dls')
tracker1 = isense.addTracker(port=1)
tracker2 = isense.addTracker(port=2)
# I tried the scripts upto here first. Then I added the following also
station1 = isense.addTracker(port=1,station=1)
station2 = isense.addTracker(port=1,station=2)
The out put looks like:
** Loading intersense connection.py
intersense.dls Intersense Driver v4.0.4
**Connected to Intersense device on port 1
Type: IS Precision Series
Model: IS-900 Series
Station State Time Cube Enhancement
1 ON ON 1 2 3 0
2 ON ON 2 2 3 0
3 OFF OFF None 2 3 2
4 OFF OFF None 2 3 2
5 OFF OFF None 2 3 2
6 OFF OFF None 2 3 2
7 OFF OFF None 2 3 2
8 OFF OFF None 2 3 2
File "intersense connection.py", line 7, in ?
AttributeError: 'VizIntersense' object has no attribute 'addTracker'
** Load Time: 2.50 seconds
InterSense Library ver. 4.04 32-bit
Copyright 1998-2007 InterSense Inc.
http://www.intersense.com
Tel: 781-541-6330
Looking for InterSense tracking device number 1.
Please wait .
IS-900 Series device detected on port 1, 115200 Baud
Firmware Version: 4.2601
Old 12-06-2010, 08:28 AM
Mr. Jeff,
If you have time , please answer my question.
Blesson
Old 12-06-2010, 05:13 PM
Try using intersense.dle. The reference page in the Vizard help gives all the commands available for this plug-in. The following code connects to 2 stations of an IS-900 on COM1:
isense = viz.add('intersense.dle')
It sounds like you may have intererence in the room if the orientation is changing without moving the sensor.
Properly aligning the intersense with the PPT Systems Z Axis shivanangel Precision Position Tracker (PPT) 0 11-10-2009 11:35 AM
world is tilting - intersense or code problem? billjarrold Vizard 2 11-06-2009 08:03 AM
Linking and Intersense Question durf Vizard 1 07-23-2009 10:09 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
using demo with intersense G-Chan Vizard 1 02-06-2006 02:05 PM
