Old 09-21-2010, 11:53 AM
Philippe Philippe is offline
limiting object rotation
Is there a method enabling to limit the range of rotation of a tracking device (Euler) relatively to the orientation of another tracking device (in my case, I have a gun which orientation's follows the glove position, and I would like to limit the orientation of the gun so that it cannot point backwards but only forwards - i.e. limiting the yaw of the gun to a range from -90 degrees to +90 degrees relatively to the current direction of the HMD).
Is there a simple way to do this?
In order words, I would like not to enable the gun to point backwards (this is some workaround solution: due to some tracking issues, it happens that the gun suddenly "flips back" and stays pointing backwards even when the glove stays more or less in the north direction ; I would like to have the glove never identified as pointing south).
Philippe.
Philippe
Old 09-21-2010, 02:30 PM
Chapre Chapre is offline
You could reset the yaw to 90 degrees or -90 degrees everytime the gun try to go beyond the limit.
Ex:
rho=gun.getEuler()
if 90 < rho[0] < 180:
---> rho[0]=90
elif -180 < rho[0] < -90:
---> rho[0]=-90
gun.setEuler(rho)
Old 10-07-2010, 12:40 PM
Thanks a lot !
Philippe
Old 10-07-2010, 12:51 PM
But where should I put such a code in the viztracker file? I would like to have this check permanently running - should I put it in the _addTracker() method ?
Philippe
Old 10-07-2010, 01:07 PM
Actually, I think that the best way is to use:
def udpateGunPosition():
(the code)
and then use
vizact.ontimer(0,udpateGunPosition)
in the main program.
This should do the job, right?
Philippe
Old 10-07-2010, 04:31 PM
masaki masaki is offline
Can you attach your script and I can take a look.
Masaki
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 08:39 AM
Object rotation Andrey Vizard 4 06-13-2007 02:49 PM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 11:33 AM
