				vizinfo in multiple scenes
			hi, im trying to use the vizinfo module but the boxes only seem to appear in scene 1.
	how can I add an info box to a different scene (while in another one)? or how can I make a box appear after calling viz.scene(#>1) ? thanks  |
	Do you want the same box in different scenes? If so, try the following: Code:
	info = vizinfo.add(....) #Duplicate the box onto scene 2 info._group.duplicate(2) Code:
	info.group.duplicate(2)  |
			how should i do it if I want to add multiple vizinfos into different scenes (at least 2 per scene).
	also, is there a way I can check the version number of vizard so i can send an error message if the user tries to run a script in an older version?  |
	To add the vizinfo box to a different scene try the following: Code:
	#Place info box in scene 2 info._group.parent(viz.WORLD,2) Code:
	version = viz.version()  |
			so i tried what you suggested, but it doesn't seem to work.  i even made a little test script:
import vizinfo
viz.clearcolor(.5,.5,.5)
info = vizinfo.add('message')
scene = 1
def onkeydown(key):
	global info, scene
	#The keyboard button 'key' is being pressed
	if key == ' ':
		scene += 1
		viz.scene(scene)
	if key == 'd':
		info._group.duplicate(scene)
	if key == 'm':
		info._group.parent(viz.WORLD, scene)
			My bad, it should be:
	info._group.parent(viz.SCREEN, scene)  |
			ok, so the parent trick works (maybe this should be added as a feature in future versions?).  now i get an error when i try to scale vizinfo.  what i have is this:
	INFO_SIZE = [0.5,0.5]
info = vizinfo.add('blah')
info.scale(INFO_SIZE)
    File "<string>", line 12, in ?
    File "context_recall_02.py", line 123, in ?
        infoBox.scale(INFO_SIZE)
TypeError: scale() takes exactly 3 arguments (2 given)
			The older version of vizinfo didn't support passing lists to the scale function. You will have to pass each value individually:
	info.scale(INFO_SIZE[0],INFO_SIZE[1]) Code:
	info.scale(*INFO_SIZE)  |
			i have both 2.5 and the previous version (2.1?) installed.  I was getting that error while using 2.5.  Is it possible vizard was grabbing the vizinfo from the older version?
	also, random python question. is there a python equivalent to: x = (isBoolean)? y:z i have a lot of checks, and i'm tired of repeating the 4 line if/else template
			It might be possible. Startup 2.5 and check the value of the following in the interactive window:
	viz._WIN_VIZ_PATH Python doesn't support the one line if/else. If you can guarentee that the value of the boolean will always be either 0 or 1 you could do the following: Code:
	x = [z,y][isBoolean] Code:
	def ifelse(boolean,trueVal,falseVal): if boolean: return trueVal return falseVal x = ifelse(isBoolean,y,z)  |
