Old 04-15-2010, 07:01 AM
Josh Josh is offline
MotionBuilder: Can calibration be saved and used for diff. persons?
Hi all
I have to send 48 different persons as avatars into a virtual world using PPT-Studio 2008 and MotionBuilder 2010.
I'm very new to this topic, and I find it very cumbersome to calibrate a person using MotionBuilder etc. so its movements are captured well (in fact I have big problems to get the movements to work smoothly, see my other topic about this: http://forum.worldviz.com/showthread.php?t=2698).
So I wondered whether it is necessary to calibrate MotionBuilder for every single person I test, or if it's possible to calibrate the stuff, then save the configuration and use it for every other person, too?
Thanks for help,
Josh
Old 04-15-2010, 11:42 AM
Yes, you could save different templates according to participant height and then re-use them. Calibrating for each person, however, will give the best results.
