Old 01-06-2005, 11:00 AM
Johannes Johannes is offline
Move Objects
I'm trying to move a ball through a room.
I know that there are certain built in functions to move it, but as I want to be very flexible I want / have to write my own movement-function.
def moveIt2():
for i in range(1,10):
print 'hallo',i
x=x0+i*0.01
y=y0+i*0,03
ball.translate(x,y,6)
i=i+1
time.sleep(0.1)
But it does not seem to work.
Without the ball.translate(x,y,6) the Function seems to work. But it prints out the numbers as a whole after in this case 1 seconds
What would you recommend for moving an object?
I know about ball.goto(3,3,6,5) or the timer-funktion-based movement. But as I want to slow down the motion sometimes (and not change speed) I will need my own timer - this is why I tried the sleep-command.
Thank you,
Johannes
Old 01-06-2005, 11:12 AM
Are you executing your moveIt2 function as a director function? If not then your function will stall the graphics frame until it is finished. To execute your code as a director function do the following:
viz.director(moveIt2)
This will execute your function asynchronously. Whenever you call the sleep command outside of a director function or thread you are effectively causing the graphics loop to sleep also.
Old 01-06-2005, 12:50 PM
Thank you for answering so fast!
But I still get an error for the sleep-command:
File "basic_test1.py", line 41, in moveIt2
time.sleep(0.1)
TypeError: a float is required
Old 01-06-2005, 12:58 PM
I'm not sure why you are getting that error. Try the following:
time.sleep(float(0.1))
Old 01-06-2005, 01:34 PM
Found it, the error was at the line
y=y0+i*0,03
(Accidently a comma slipt in)
Short question to hierarchical Objects - guess (as I tried) this is not possible:
Say I want an object to move with it's shadow.
ball = viz.add('../resources/models/ball.wrl')
shadow = viz.add('../resources/models/shadow.wrl')
shadow.translate(0, 1, 0, viz.RELATIVE)
shadow.alpha(0.7)
shadowBall=ball.add(shadow)
Old 01-06-2005, 02:34 PM
To attach the shadow to the ball you would do the following:
ball = viz.add('ball.wrl')
shadow = ball.add('shadow.wrl')
or you can leave it the way you have it but change the last line to the following:
shadow.parent(ball)
Old 01-07-2005, 11:47 AM
Thank you, this works!
Old 01-19-2005, 07:38 AM
Is it correct if I conceptualize the director-function similar to starting a thread in Java?
Johannes
Old 01-19-2005, 10:15 AM
Yes, the director function is basically a thread.
