Old 03-07-2010, 01:57 PM
Josh Josh is offline
unset onkeydown for a key?
Hi all
Is there a way to unset the onkeydown for a key once you already assigned it an action?
Josh
Old 03-07-2010, 10:16 PM
IGoudt IGoudt is offline
You can use:
viz.callback(viz.KEYDOWN_EVENT,None)
I guess you can also use:
vizact.onkeydown(key, None)
Depending if you use vizact or viz.callback to handle your events.
Old 03-08-2010, 02:37 AM
Thanks so far...
The space bar should only be pressed once in my experiment:
vizact.onkeydown(' ', play_first_joke)
As soon as it's been pressed, it shouldn't invode the play_first_joke method anymore.
vizact.onkeydown(' ', None)
...gives the following error:
  File "C:\Programme\WorldViz\Vizard30\python\vizact.py", line 3019, in __onkeydown
    self._callGroup(self.__keydownmap[key])
  File "C:\Programme\WorldViz\Vizard30\python\vizact.py", line 2971, in _callGroup
    val = e.call(arg)
  File "C:\Programme\WorldViz\Vizard30\python\vizact.py", line 2794, in _callStatic
    return func(*args,**kwargs)
TypeError: 'NoneType' object is not callable
Old 03-08-2010, 04:01 AM
After searching in the documentation I found the following:
<vizact>.removeEvent
Deletes an EventFunction object
<vizact>.removeEvent( eventFunctionObj )
eventFunctionObj
Remarks
Uses this when you no longer need an EventFunction callback.
Return Value
None
Example
eventFunction = vizact.onupdate( 5, doSomething )
vizact.removeEvent( eventFunction )
Old 03-08-2010, 04:03 AM
Thank you. But I don't know how exactly I can use this now... I'm sorry, I'm absolutely new to Python and to the theories that stand behind events in WorldViz...
Old 03-08-2010, 04:24 AM
Whenever you register a function with vizact.onkeydown a reference is made in memory between the keystroke and the function. What you wish to achieve is to break that reference. A way to do that, have your program memorize that reference as a variable and then do some operation on that variable, in this case: removeEvent.
Take for example:
def initialiseProgram():
     playJokeEvent = vizact.onkeydown(' ', play_first_joke)
     ... other initialisation
def play_first_joke():
     vizact.removeEvent(playJokeEvent)
     .. do your fancy scene stuff here
I have to admit that I am used to program OOP in classes, and the handling of variables is different when using classes in python than when using direct code (self, vs, global). Try this code snippet first, if it doesn't work out well then we might to do some hacking with the [global] statement.
Old 03-08-2010, 12:49 PM
Thanks, that helps a lot. :-)
onkeydown list of values Cheff Vizard 2 07-02-2008 02:00 AM
