Old 02-08-2010, 05:08 PM
ssaha ssaha is offline
Some Problem in navigation
I have been trying to use UserAvatar.py for navigation from link:
http://vizworkshop.com/articles/walkthrough_app
I did two following changes in UserAvatar file:
Change 1: In _init_ function, I used collideBox in place of collideCapsule.
Change 2: In updatePrePhysics, I changed headEuler following way:
headEuler = self.head.getEuler(viz.ABS_GLOBAL)
headEuler[0] = headEuler[0] + yawChange
headEuler[1] = headEuler[1]
headEuler[2] = headEuler[2]
self.head.setEuler(headEuler, viz.ABS_GLOBAL)
Problem: In code, there is no change of y-coordinate of self.feet. According to code, it should be
always zero (0). But when I run the code with above change, I get change in y-coordinate of self.feet. So in order to keep it zero, I add following code in updatePostPhysics:
temp_pos= self.feet.getPosition(viz.ABS_GLOBAL)
temp_pos[1]=0
self.feet.setPosition(temp_pos)
After doing this , y is zero . But movement is not smooth.
Could you give some solutions? For your convenience, updated UserAvatar.py is attached below.
import vizmat
import viztask
class UserAvatar(viz.EventClass):
THROTTLE_SPEED = 4
HYPER_THROTTLE_SPEED = 30
TURN_SPEED = .1
def __init__(self):
viz.EventClass.__init__(self)
self.feet = viz.addGroup(pos=[0, 0, 0]) #position of user avatar
#physics init
self.physicShape = self.feet.collideBox([0.5,1,0.5],friction=.00000001, hardness=.0000001, bounce=0)
self.velMotor = self.feet.addVelocity(velocity=[0,0,0], maxForce=100, gravity=False))
#orientation of user avatar
self.head = viz.addGroup()
#view should link to this
self.avatar = viz.mergeLinkable(self.feet, self.head)
self.count =0;
self.mouseDx = 0
self.mouseDy = 0
self.callback(viz.MOUSE_MOVE_EVENT, self.onMouseMove)
vizact.onupdate(viz.PRIORITY_PHYSICS-1, self.updatePrePhysics)
vizact.onupdate(viz.PRIORITY_PHYSICS+1, self.updatePostPhysics)
def updatePrePhysics(self):
print "count " +str(self.count)
self.count =self.count+1
throttle = vizmat.Vector([0,0,0])
print "vizmat.Vector:Feet Pos: " + str(self.feet.getPosition(viz.ABS_GLOBAL))
## Steer Control
yawChange = self.mouseDx * self.TURN_SPEED
pitchChange = -self.mouseDy * self.TURN_SPEED
#discard old mouse movement and start collecting new mouse input
self.mouseDx = 0
self.mouseDy = 0
## Translate Control
throttle.set([0,0,0])
#forward/back
if viz.key.isDown('w') or viz.mouse.getState() & viz.MOUSEBUTTON_LEFT:
throttle += [0,0,1]
if viz.key.isDown('s') or viz.mouse.getState() & viz.MOUSEBUTTON_RIGHT:
throttle += [0,0,-1]
#left/right
if viz.key.isDown('a'):
throttle += [-1,0,0]
if viz.key.isDown('d'):
throttle += [1,0,0]
throttle.normalize() #<--direction
print "throttle.normalize:Feet Pos: " + str(self.feet.getPosition(viz.ABS_GLOBAL))
print "throttle.length():Feet Pos: " + str(self.feet.getPosition(viz.ABS_GLOBAL))
if viz.key.isDown(' ') or viz.mouse.getState() & viz.MOUSEBUTTON_MIDDLE:
throttle *= self.HYPER_THROTTLE_SPEED
throttle *= self.THROTTLE_SPEED
print "viz.key.isDown:Feet Pos: " + str(self.feet.getPosition(viz.ABS_GLOBAL))
if throttle.length(): #if throttle not zero
#move forward in direction of head
newVel = vizmat.Transform()
newVel.setTrans(throttle)
newVel.postEuler(self.head.getEuler(viz.ABS_GLOBAL ))
self.velMotor.setVelocity(newVel.getTrans())
print "hey"
#self.velMotor.setVelocity([0, 0, 0])
def updatePostPhysics(self):
print "updatePostPhysics " + str(self.feet.getPosition(viz.ABS_GLOBAL))
self.feet.setEuler([0, 0, 0])
def onMouseMove(self, e):
#fuction called twice, once for movement on x axis, once for y axis
print "onMouseMove " + str(self.feet.getPosition(viz.ABS_GLOBAL))
self.mouseDx = self.mouseDx + e.dx
self.mouseDy = self.mouseDy + e.dy
def linkView(self, view):
return viz.link(self.avatar, view, srcFlag=viz.LINK_ABSOLUTE, dstFlag=viz.LINK_POS_RAW)
def setPosition(self, xyz):
self.feet.setPosition(xyz)
print "setPosition " + str(self.feet.getPosition(viz.ABS_GLOBAL))
def setEuler(self, euler):
self.head.setEuler(euler)
if __name__ == '__main__':
viz.move([0, 0, -2])
viz.phys.enable()
t = viz.add('tankmaze.wrl')
t.collideMesh(bounce=0, hardness=1, friction=0)
user = UserAvatar()
user.feet.setPosition([0, 0, 0])
user.linkView(viz.MainView)
Old 02-09-2010, 08:40 AM
Please disregard my previous post
temp_pos[1]=0
Could you give any solution? For your convenience, updated UserAvatar.py is attached below.
Moves the view according to user input
import vizmat
import viztask
	THROTTLE_SPEED = 4
	TURN_SPEED = .1
	def __init__(self):
		#physics init
		self.mouseDx = 0
		self.mouseDy = 0
		## Steer Control
		self.mouseDx = 0
		self.mouseDy = 0
		#forward/back
			throttle += [0,0,1]
		#left/right
			throttle += [1,0,0]
			newVel.postEuler(self.head.getEuler(viz.ABS_GLOBAL))
	viz.phys.enable()
	user = UserAvatar()
Old 02-10-2010, 10:28 AM
Replied to here:
http://vizworkshop.com/articles/walk..._app#comment-3
Answer:
I could not reproduce the problem. I made your changes to UserAvatar.py and movement is smooth. Perhaps if you post your UserAvatar.py I can see your problem. The one you posted does not have your change to the "updatePostPhysics" method.
The problem could be because your moving the physics shape/box inside of another physics object, the tankmaze floor, with your updatePostPhysics method. This could be generating some strong "repelling" forces and make your movement jerky/weird. Hold the feet Y value at 1 or above to fix.
Also, the corners of collideBox cause some funky jerks when running into the hedra shape. Change back to smooth object like capsule or sphere to fix.
Old 03-24-2010, 01:21 PM
My code
Thanks for your reply.
According to your instruction, I changed. But, still, movememnt is not smooth. Please check the attached code.
navigation in cave environment Andy Vizard 4 03-28-2008 01:32 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
