Thread Tools Rating: Thread Rating: 3 votes, 1.33 average. Display Modes
Old 11-09-2004, 04:19 PM
adimov adimov is offline
vizrecorder
I get an error (winviz.exe has encountered a problem and....) when I try to use the vizrecorder.dll. I am running the following code and it crashes when I press spacebar:
import vizrecorder
text = viz.add(viz.TEXT3D,'Recording',viz.SCREEN)
text.alignment(viz.TEXT_CENTER_CENTER)
text.translate(0.5,0.5)
text.visible(0)
text.recording = 0
def mykey(key):
if key == ' ':
text.recording = not text.recording
text.visible(text.recording)
if text.recording:
vizrecorder.record('voice.wav')
vizrecorder.stop()
viz.callback(viz.KEYBOARD_EVENT,mykey)
Old 11-09-2004, 04:29 PM
Run the script without pressing the spacebar. Does it output anything? It should print out something along the lines of "** NOTIFY: Found the following sound capture devices:"
Old 11-09-2004, 04:33 PM
rosanna rosanna is offline
it says: error, could not initialize direct sound
Old 11-09-2004, 04:43 PM
It should also print out another line that says what caused the error. Either way, can you check that DirectX 8.0 or above is installed on your computer.
To check, click the Windows Start menu, then Run. Type in "dxdiag" then press enter. A dialog should appear. On the first page of the dialog there will be a field that says "DirectX version:"
Old 11-09-2004, 04:48 PM
thanx for the help, the problem turns out to be related with the sound card.
alex
