Old 07-14-2009, 08:35 AM
Dave Dave is offline
dlr water surface
Hi - back in 2006 there was a great routine posted on the forum for creating a sea surface using a water.dlr file and a water.rgb file. Does anyone know what software is used to create the dlr file - I want to try and create one similar but with different parameters but try as I might can find nothing on the web about dlr files. All help welcome. Thanks.
Old 07-15-2009, 10:04 AM
Jerry Jerry is offline
Here is the Visual C++ 6.0 project which I used to make the
water plugin. You can play around with the parameters in
the ModifyWater() function of water.cxx. Please don't ask
me details about how it works because I don't know.
Old 07-15-2009, 10:09 AM
I forgot, you will need to put this in the same folder as the plugin.
Or you can use a different rgb image file to give the water a different
look, but it still must be named "water.rgb".
Old 07-17-2009, 09:05 AM
Thanks Jerry - much appreciated
Water rendering... help! k_iwan Vizard 13 04-04-2014 11:57 AM
Surface animation and bone motion Dave Vizard 5 09-26-2007 02:52 PM
