Old 09-21-2004, 09:59 AM
vr_boyko vr_boyko is offline
Animating an out-of-body transition
greetings!
I would like to construct an animation that swings the viewport around to look at the avatar representing the person who is looking through the viewport while moving away to a pre-determined position external position, a sort of an out-of-body experience. Currently I am trying to achieve this by using the commands:
<viewpoint>.goto(x,y,z,vel)
and
<viewpoint>.lookat(x,y,z)
my actual code looks like this:
def outofmymind(): # animate a smooth POV transition
global myAvatar
myApos = myAvatar.get(viz.POSITION)
myPOV = viz.get(viz.MAIN_VIEWPOINT)
myPOV.lookat(myApos)
myPOV.goto(5,5,5,.85) #just an arbitrary external place
however, instead of going to (5,5,5) in about 2 seconds while looking at myAvatar, the viewport just sinks down (-y)
any comments on my (apparently wrong) code and any suggestions for improvement are very appreciated.
btw, what formatting do you use especially for code, and how do I access it from "post new thread" webpage (is it in enhanced mode?)
Old 09-21-2004, 10:30 AM
Take a look at the <viewpoint>.gotomode and <viewpoint>.pivot commands. Also, there is an example script in the [Vizard20]/examples/advanced directory called animateview.py which shows how to use these functions.
Basically what you would want to do is something like the following:
	myPOV.gotomode(viz.BLEND_ROTATE) #Also try out 	viz.PIVOT_ROTATE, see which one you like better
	myPOV.pivot(myApos)
To format some text as code you can press the button with the "#" symbol or you can manually add the following tags around it: [ code ]some code[ /code ]
Old 09-21-2004, 11:30 AM
works great! thanks
I found that the BLEND_ROTATE feels more natural, as much as an out-of-body experience can feel natural.
thanks again!
