Old 09-13-2004, 05:25 PM
valhalla valhalla is offline
dynamic access of avatar location
I've been trying to calculate the distance between two avatars by getting their centres and using pythagoras to get the distance. However, I've ran into a walk concerning how to get the positions of the avatars. How would I get the x coordinate, y coordinate, z coordinate of an avatar or all three in an array?
Old 09-13-2004, 08:28 PM
tobin tobin is offline
An avatar is a subclass of a node3d object. If you look under the help "command reference" for node3d objects, you'll see a method called "get". It can get the position along with many other states of any valid node3d object. Refer to the docs for syntax.
