Thread Tools Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Old 09-13-2004, 05:24 PM
vduckie vduckie is offline
avatar animations
I was using the avatar animations (for example, the sit and the shot) and the avatars always return to their original standing position after completing their animation. For example, if I use viz.act(sit) the avatar will sit down, then pop up back to their original standing position and stay there. If I use viz.state(sit) the avatar will sit down, return to their original position, and continue repeating this. How you you make the avatar sit down and stay there?
So whether I used viz.act or viz.state, I can't seem to get the avatar to do their action (sit or get shot) and then stay where they are (sitting or lying on the ground). How do you get them to stop returning to their original position every time?
Thanks.
Old 09-14-2004, 09:36 AM
Currently, the only way to do this is to use the avatar.speed command. When you set the speed of an avatar to 0, it will effectively freeze it.
I wrote a very short script that shows how to do this. Press the spacebar to activate the animation of the avatar being shot. Once the animation is activated, a timer will be set to expire when the animation is over. The timer will then freeze the avatar.
FREEZE_AVATAR = 0
male = viz.add('male.cfg')
male.rotate(180,0,0)
viz.move(0,0,-8)
def onkeydown(key):
	if key == ' ':
		#Perform the action
		male.act(7)
		#Start a timer to freeze the avatar when the action is over
		viz.starttimer(FREEZE_AVATAR,male.getduration(7))
def ontimer(num):
	if num == FREEZE_AVATAR:
		#Freeze the avatar
		male.speed(0)
Let me know if you need any more help
Old 02-15-2006, 04:45 PM
still stuck
I tried running this piece of code and the avatar stood back up. Have you found any other methods of "freezing the avatar"? Also, I'm trying to run the animation of someone getting shot then laying on the ground. I'm not sure if that's different from the sit and shot animation.
Thank you,
Old 02-15-2006, 05:06 PM
Try replacing the starttimer code with the following instead:
viz.starttimer(FREEZE_AVATAR,male.getduration(7)-0.1)
This will create a buffer zone to ensure the avatar is frozen before the animation fully completes. It should also work with your animation too.
Old 02-15-2006, 05:51 PM
Yes, I did viz.starttimer(FREEZE_AVATAR,(male.getduration(7)-.06).
By the way, how do you enter code into this forum? I'm sorry I'm asking so many questions, but you have been very helpful. I would like to show you the code I'm working on, but don't know how to format it.
Old 02-15-2006, 05:56 PM
Nevermind that last question, I just figured it out. Now for my real question. The reason I'm writing this code is to create a scenario where someone falls when they get shot (i.e. a projectile hits the avatar, activated by a mouse click). I have modeled my code from the duckcourt demo but can't get the enemy to stay on the ground when shot. I'm thinking it has to do with the way the avatar is "viewed" by the program. I was wondering if you could help me figure out how to distinguish between each element in the array and denote who's getting shot. For now I would be happy just being able to click on the avatars in this code and have them fall and stay down. I think I can go from there. Thanks again
avatars = []
FREEZE_AVATAR = 0
#Go through a loop six times.
for i in range(4):
	#Each time you go through the loop, create a new duck and
	male.translate(-i, 0,10)
#Add the new male to the "avatars" array.
	avatars.append(male)
def onkeydown(key):
	if key == 'r':
		print 'R pressed'
		# Kill timer FREEZE_AVATAR
		viz.killtimer(FREEZE_AVATAR)
		male.clear(viz.ALL)
		male.clear(viz.CURRENT_ACTION)
		male.state(1)
def ontimer(num):
		#Freeze the avatar
		male.speed(0)
def onmousedown(button):
	#The mouse button 'button' is being pressed
			#Perform the action
			male.act(7)
			viz.starttimer(FREEZE_AVATAR,(male.getduration(7)-.07),1)
			#male.act(8)	pass
viz.callback(viz.MOUSEDOWN_EVENT,onmousedown)
viz.mouse(viz.OFF)
Old 02-16-2006, 11:49 AM
The code below will create six avatars and allow the user to click on any of them to cause them to fall down and stay down. Let me know if anything is unclear.
avatars = []
#Create six avatars
for i in range(6):
	male.translate(i,0,0)
	avatars.append(male) #Save avatar in list
		node = viz.pick() #Get object that was clicked
		if node in avatars: #Check if object is one of the avatars
			node.execute(7) #Execute the "shot" animation
			#Create action to wait for the animation duration then freeeze the avatar
			WaitThenFreeze = vizact.sequence( vizact.waittime(node.getduration(7)-.06), vizact.speed_node(0) )
			node.add(WaitThenFreeze) #Add the action to the avatar
#Move viewpoint so that all avatars are visible
viz.move(2.5,0,-10)
#Disable mouse navigation
viz.mouse(0)
Old 02-17-2006, 12:36 PM
Question Collidesphere
I have this bit of code that I am using from the duckcourt example. I can't find anything on the help that deals with collidesphere. Where did that come from and what does it mean.
	#Enable collisions with the ball based on a sphere shape
	ball.collidesphere(0.25)
	ball.isTarget = 0
	collidables.append(ball)
Old 02-17-2006, 02:04 PM
The command tells Vizard to use a sphere with radius 0.25 when checking collisions with the objects using the collidingwith command. The collide functions are currently undocumented. Let me know if you want more information.
Old 02-24-2006, 01:16 PM
I was wondering if you could help me out. I'm trying to add an animation where, if I click on an avatar, it falls to the ground and disappears. I got the falling part down, but I added the fadeReset sequence to try and delay the disappearing and it doesn't work out. Any ideas?
			node.clear(viz.ALL)
			node.clear(viz.CURRENT_ACTION)
			WaitThenFreeze = vizact.sequence( vizact.waittime(node.getduration(7)-.139), vizact.speed_node(0))
			fadeReset = vizact.sequence(vizact.waittime(5),node.remove())
			#vizact.sequence(vizact.waittime(2),avatars.remove(male),1)
			node.add(fadeReset)
Old 02-24-2006, 02:09 PM
The problem is that you are calling node.remove(). This function will immediately delete the object. In this example you need to create an action that will remove the node. Use the following code instead:
fadeReset = vizact.sequence(vizact.waittime(5),vizact.call(node.remove))
The vizact.call action will simply call the function that you pass to it.
Old 02-27-2006, 01:00 PM
I think it's working out but I do get some traceback errors. Here is the code:
	global i
			node.clear(viz.ALL)
			WaitThenFreeze = vizact.sequence( vizact.waittime(node.getduration(7)-.14), vizact.speed_node(0))
			node.clear(viz.ALL)
			node.clear(viz.ALL)
			fadeReset = vizact.sequence(vizact.waittime(1),vizact.call(node.remove))
			node.add(fadeReset)
		i = 2;
Here are the traceback errors. I'm not sure what they all mean.
  File "C:\Program Files\Vizard25\viz.py", line 5916, in mytimer
    curAction.update(elaps,curAction._obj_)
  File "C:\Program Files\Vizard25\vizact.py", line 653, in update
    self.checkaction(object)
  File "C:\Program Files\Vizard25\vizact.py", line 629, in checkaction
    __endAction__(object,self.curAction)
  File "C:\Program Files\Vizard25\vizact.py", line 219, in __endAction__
    object._action.notifyEndAction(action._obj_,action._actiondata_.callbackData,action._pool_)
AttributeError: 'int' object has no attribute 'notifyEndAction'
Old 02-27-2006, 01:32 PM
Try the following instead:
node.add(vizact.waittime(1))
node.add(vizact.call(node.remove))
