Old 11-21-2008, 12:25 PM
just alex just alex is offline
Problems with spawn point.
I'm kinda new with this, so it's probably a beginner's mistake on my part, but I keep having problems with the spawn point of the subject on my code. For some reason, whenever I load the code, it spawns about 10-14 feet above the ground level. I've tried just translating the head point down, but I can only get it to spawn either into the ground (at -2 and lower) or get no change. Does anyone know how I can fix this?
-Alex
Old 11-24-2008, 09:51 AM
Are you using viz.MainView.setPosition() to translate the viewpoint? Are you sure your ground model is at the correct height? It's hard to tell what is going on without any sample code.
Making avatar point with hand towards dan12345 Vizard 7 08-17-2017 06:12 AM
Incoming floating point values Rachel Vizard 1 02-12-2008 03:09 PM
data glove navigation arielasso Vizard 6 10-24-2007 02:15 PM
looking at a point vadrian Vizard 5 06-07-2005 05:43 PM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
