Old 09-30-2008, 01:53 AM
Prune Prune is offline
Unhappy Maya 8.5 Cal3D exporter not working
My boss has Maya 8.5 Unlimited, and I put the plugin in the plugins folder and cal3d.dll in the bin folder, and Maya detects the plugin but when I try to load it it gives me error: the specified procedure could not be found
I even tried different versions of cal3d.dll, including one I built, and others from the Cal3D binary distributions and from a separate 3D studio exporter.
Old 10-02-2008, 10:44 AM
Did you try the version of cal3d.dll that comes with Vizard 3.0?
Old 10-07-2008, 02:56 PM
Hi, thanks for the suggestion, I got it to work. I'm wondering why other versions of the dll don't work. Is the Cal3D in Vizard not a standard published version?
Old 10-07-2008, 04:29 PM
Vizard uses a somewhat older version of cal3d that has been slightly modified, so it is probably incompatible with the versions available on the cal3d website.
Old 10-08-2008, 11:36 AM
I've seen a branch version on the web that adds keyframed morph animations, is that the one? How would I go about exporting animated morphs?
Old 10-09-2008, 05:15 PM
We are using an older version that does not support exported morph animations.
cal3d exporter for 3ds max 2008? masaki Plug-in development 3 09-25-2008 10:48 AM
Trouble Loading Maya7 Cal3d Exporter tbeckert Vizard 3 11-06-2007 09:38 AM
Maya + cal3d krimble Vizard 1 08-15-2007 06:51 AM
cal3d exporter issue reiverlass Vizard 4 07-18-2007 12:08 PM
cal3d exporter problem visnova Vizard 1 06-15-2007 03:02 PM
