how to bind text to objects
i have a question, you know how in the tutorials it shows how to bind the mona lisa video to the screen? how would i do this with text... so that if also the player press a button, the screen would go up, and the text along with it.
any suggestions...? |
You will need to manually scale and position the text so that it lies on the screen surface. You will probably need to use the zoffset command also, to prevent z-fighting artifacts.
i don't understand too well, what you mean by this... is there a tutorial on such thing?
thanks btw |
There is no tutorial that directly addresses this issue. You just need to use the standard node.setPosition/setEuler/setScale functions to place the text where you want it to show up, in this case on top of the screen.
I have some code that you can feel free to use. It might be overkill but it should do the job.
It uses an action to build a billboard like behavior. eg. the billboard node looks directly at the camera position rather than matching the camera alignment. It was useful in a cave scenario. It also deals with Z order and depth write to ensure the text is visible. Otherwise you just call AttachSpeechBubble to float some text above an object. Code:
import viz viz.go() #########Utility Class and Functions for Speech Bubble############ # all you need to call is AttachSpeechBubble #code is based upon worldviz avatar lookat tutorial MAXLINELENGTH = 60 class BillboardToNodeAction(viz.ActionClass): def begin(self,object): """Called once when action starts""" self.nodeToLookAt = self._actiondata_.data[0] self.nodeToModify = self._actiondata_.data[1] self.duration = self._actiondata_.data[2] self.blendIn = self._actiondata_.data[3] self.timeElapsed = 0 self.startQuat = self.nodeToModify.getQuat() def update(self,elapsed,object): self.timeElapsed += elapsed p = 1 if self.blendIn <> 0.0: p = self.timeElapsed / self.blendIn positionToLookAt = self.nodeToLookAt.getPosition() for ix in range(3): positionToLookAt[ix] = self.nodeToModify.getPosition()[ix] + self.nodeToModify.getPosition()[ix] - positionToLookAt[ix] if self.duration > 0.0 and self.timeElapsed > self.duration: self.nodeToModify.lookat(positionToLookAt, 0, viz.ABS_GLOBAL) self.end(object) elif p < 1.0: self.nodeToModify.lookat( positionToLookAt, 0, viz.ABS_GLOBAL ) targetQuat = self.nodeToModify.getQuat() nextQuad = vizmat.slerp(self.startQuat,targetQuat,p) self.nodeToModify.setQuat(nextQuad) else: self.nodeToModify.lookat(positionToLookAt, 0, viz.ABS_GLOBAL) def end(self,object): viz.ActionClass.end(self,object) #Function to construct the action instance def billboardNode( nodeToLookAt, nodeToModify, duration = viz.FOREVER, blendIn = 0.0): action = viz.ActionData() action.data = [ nodeToLookAt, nodeToModify, duration, blendIn ] action.actionclass = BillboardToNodeAction return action def FormatTextbox(msg): length = len(msg) lastspace = 0 while lastspace + MAXLINELENGTH < length and lastspace <> -1: lastspace = msg.rfind(' ',lastspace, lastspace + MAXLINELENGTH) if lastspace > 0 and lastspace < length: msg = msg[:lastspace] + '\n' + msg[lastspace+1:] else: lastspace = -1 lines = msg.splitlines() return lines def AttachSpeechBubble(dest,message, height = 1.8): lines = FormatTextbox(message) rootline = 0 parentline = 0 for lineix in range(len(lines),0,-1): speechline = viz.addText(lines[lineix-1]) speechline.alignment(viz.TEXT_CENTER_BOTTOM) if not rootline: rootline = speechline parentline = speechline else: speechline.parent(parentline) parentline = speechline speechline.translate([0,1.0,0]) speechline.draworder(13) speechline.depthFunc(viz.GL_ALWAYS) speechline.disable(viz.DEPTH_WRITE) speechtext = rootline speechbox = speechtext.getBoundingBox() speechtext.setScale([0.12,0.12,0.12]) viz.startlayer(viz.QUADS) viz.vertex(speechbox.xmin-0.1,speechbox.ymax+0.1,0) viz.vertex(speechbox.xmax+0.1,speechbox.ymax+0.1,0) viz.vertex(speechbox.xmax+0.1,speechbox.ymin-0.1,0) viz.vertex(speechbox.xmin-0.1,speechbox.ymin-0.1,0) speechquad = viz.endlayer() speechquad.color([0,0,0]) speechquad.disable(viz.CULL_FACE) speechquad.parent(speechtext) speechquad.draworder(12) speechquad.alpha(0.5) speechquad.depthFunc(viz.GL_ALWAYS) speechquad.disable(viz.DEPTH_WRITE) if type(dest) == list: speechtext.translate(dest) else: linkposition = viz.link(dest, speechtext) linkposition.setMask(viz.LINK_POS) linkposition.preTrans([0, height, 0]) speechtext.addAction(billboardNode(viz.MainView,speechtext)) return speechtext ################################# viz.clearcolor(0,0,0.5) box = viz.add("box.wrl") box.setPosition(0,2,7) AttachSpeechBubble(dest = box,message = "This text floats above the box",height = 1.0) |
what is this 'AttachSpeechBubble' you speak of? will it allow an avatar to have a floating text bubble if an event is triggered?
Similar Threads | ||||
Improve performance with large number of onthefly objects? | Fox5 | Vizard | 7 | 04-28-2008 05:19 PM |
text output | jaclyn.bill | Vizard | 2 | 10-24-2007 06:37 AM |
Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
adding 2D text via script | V.shazzle | Vizard | 3 | 09-19-2005 02:45 PM |
3d Text with Transparent Borders | vjosh | Vizard | 3 | 12-01-2004 10:50 AM |
