Old 07-24-2008, 03:43 AM
dan12345 dan12345 is offline
Problem using mirror
Hello - I've been trying to use the mirror which was discussed in previous forum posts. Everything seemed to be working just fine when trying it out not on the HMD - But when i try it out with the helmet i get a very very weird bug -
the avatar linked to the viewpoint usually looks just dandy, but while moving it suddenly disappears for a second or two - this happens consistently in particular moving patterns. The avatar seems to vanish behind an invisible screen. I've put all my efforts to understand why this happens, but feel like i've run into a dead end. Would be very, very grateful, if you could help me out!
Attached after this is the code (simplified to the minimum relevant to the mirror problem)
it uses the bigroom.ive file used in the public speaking demo. There is a boolean variable TESTING at the beginning which decides if to run on the HMD or not - notice how running not on the HMD produces good results. The addMirror function was copy pasted from the one talked about in earlier forum posts....
Thanks alot
dan
THE CODE:
#coding: UTF-8
import viztracker
TESTING = False
if TESTING :
else :
print(3)
head = viztracker.add()
headlink = viz.link(head,viz.MainView)
viz.eyeheight(0)
headlink.postTrans([0,0,0.2])
viz.go(viz.HMD|viz.STEREO)
def headLightOnMirror():
light = viz.addLight()
light.setPosition(-4,1.8,1.2)
light.position(0,0,1,0)
def addMirror(mirror,mat=None):
#If mirror matrix is not specifed, get matrix of mirror object
if mat is None:
mat = mirror.getMatrix()
#Position of mirror
pos = viz.Vector(mat.getPosition())
#Direction mirror is pointing
dir = viz.Vector(mat.getForward())
dir.normalize()
#Quaternion rotation of mirror
quat = mat.getQuat()
#Create render texture
tex = viz.addRenderTexture()
#Create render node for rendering reflection
lens = viz.addRenderNode(size=[1024,1024])
lens.attachTexture(tex)
lens.setInheritView(True,viz.POST_MULT)
lens.disable(viz.CULL_FACE,op=viz.OP_SET_OVERRIDE)
#Setup reflection matrix
rot = viz.Matrix.quat(quat)
invRot = rot.inverse()
lens.setMatrix(viz.Matrix.translate(pos*-1.0)*invRot*viz.Matrix.scale(1,1,-1)*rot*viz.Matrix.translate(pos))
#Setup reflection clip plane
plane = vizmat.Plane(pos=pos,normal=dir)
dist = plane.distance([0,0,0])
lens.clipPlane([-dir[0],-dir[1],-dir[2],dist+0.001])
#Project reflection texture onto mirror
mirror.texture(tex)
mirror.texGen(viz.TEXGEN_PROJECT_EYE)
myRoom = viz.add('../art/models/bigroom.IVE')
#Apply mirror settings to mirror object
mirrorsurface = viz.addTexQuad()
mirrorsurface.scale(.3,.25,.6)
mirrorsurface.setPosition(0,1.8,1.2)
mirrorsurfacerotation = [0,0,0] #rotation around the Z,Y,X axes #changed from [90,0,0]
mirrorsurface.rotate(mirrorsurfacerotation)
m = viz.Matrix()
m.setPosition(mirrorsurface.getPosition(viz.ABS_GL OBAL))
m.setEuler(mirrorsurfacerotation[0]-180,-mirrorsurfacerotation[1], mirrorsurfacerotation[2]) #Z,X,Y
addMirror(mirrorsurface,m)
female = viz.add('female.cfg')
headLink = viz.link(viz.MainView,female)
headLink.setPos([None,0,None])
headLightOnMirror()
Old 07-25-2008, 01:30 PM
Please use the [code][/code] tags when posting code samples on the forum. It preserves the indentation, which is necessary for Python code.
I believe somebody else ran into this issue as well and I posted the fix for it. In case you cannot find it, here is the code again that should work in stereo mode.
viz.go(viz.STEREO)
REFLECT_MASK = viz.LAST_MASK << 1
	if mat is None:
	#Position of mirror
	dir.normalize()
	for eye in (viz.RENDER_LEFT,viz.RENDER_RIGHT):
		lens.setCullMask(REFLECT_MASK)
		lens.disable(viz.CULL_FACE,op=viz.OP_OVERRIDE)
		lens.disable(eye)
		lens.setMatrix(viz.Matrix.translate(-pos)*invRot*viz.Matrix.scale(1,1,-1)*rot*viz.Matrix.translate(pos))
		s = -viz.sign(viz.Vector(dir) * viz.Vector(pos))
		lens.clipPlane([-dir[0],-dir[1],-dir[2],s*dist+0.1])
		mirror.texture(tex)
#Add gallery environment
#Use existing painting as mirror and specify the matrix
mirror = gallery.getChild('art04-FACES')
m = viz.Matrix()
m.setPosition(mirror.getPosition(viz.ABS_GLOBAL))
m.setEuler(180,0,0)
addMirror(mirror,m)
#Increase ambient lighting
viz.MainView.getHeadLight().ambient(1,1,1)
#Create a self avatar
#Link avatar body to viewpoint
avatarLink = viz.link(viz.MainView,avatar)
avatarLink.setPos([None,0,None]) #Keep avatar on floor
avatarLink.setEuler([None,0,0]) #Only update avatar yaw
avatar.setMask(viz.LEFT_MASK|viz.RIGHT_MASK,mode=viz.MASK_REMOVE) #Only draw avatar in mirror
#Link avatar head to viewpoint
head = avatar.getBone('Bip01 Head')
head.lock()
viz.link(viz.MainView,head,mask=viz.LINK_ORI)
Old 07-28-2008, 04:30 AM
Hi.
I tried using the code you posted here, but now i have a problem - it uses functionality of the newest version of vizard, but as posted a while ago, the newest version of vizard does not work for us, because of intersense driver issues.... Would still be VERY happy for a fix with the driver issues, but in the meantime could you maybe post the same code using old vizard functionalities? ) the problem is in viz.matrix.translate function, in the add mirror method...
thanks, dan
Old 07-28-2008, 04:48 AM
Okay, mirror problem solved, as i changed the line that gave problems
with the line in the previous add mirror function. Intersense Driver problem still exists ofcourse though.
Strange bug concerning a mirror Frank Verberne Vizard 2 05-15-2008 05:09 AM
Eyes that keep looking at the mirror Frank Verberne Vizard 3 05-13-2008 05:39 AM
Mirror issues Frank Verberne Vizard 2 04-08-2008 10:37 AM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 08:21 AM
