Old 05-19-2008, 06:53 AM
Exclamation Stereo synchronisation
Hello Wizards !!
I got a synchronisation problem there... when I launch my application Vizard render it in stereo [frame sequential stereo]. But my glasses do not seem to separate the two frames, I still view the ghost image.
- I got nVidia stereo driver
- Stereo enabled
- settings on 19" monitor, 800x600x32 @ 120Hz
In Vizard (rendering in fullscreen, of course):
viz.ipd(0.06)
viz.viewdist(5)
Am I missing something ?
viz.FOREVER,
D.
Old 05-19-2008, 02:20 PM
If the Vizard window is flickering between the left/right eyes, then the problem lies with the hardware. Are you sure the nVidia stereo drivers support your model of shutter glasses? For example, some shutter glasses require a blue-line being rendered at the bottom of the screen for distinguishing between left/right eyes, and the stereo drivers might not be supporting this. What kind of shutter glasses are you using?
Old 05-19-2008, 03:02 PM
Arrow Hardware
I'm using NuVision 60GX + Infocus DetphQ projector...
Old 05-19-2008, 06:31 PM
I've never used those shutter glasses before, so I cannot tell you what is wrong. Do the shutter glasses come with any test programs to ensure they are functioning properly?
Old 05-19-2008, 07:40 PM
Unhappy ? Oops
wow... I only got a box of 5 glasses with the Infrared device...
D.
Old 05-19-2008, 07:59 PM
mspusch mspusch is offline
the nuvision glasses work with an IR emitter.
the emitter has a special plug (VGA break out cable) that needs to be connected to the VGA signal output that feeds the Infocus DetphQ projector.
the IT emitter needs to be placed on you projection screen or on the ceiling, so the nuvison shutterglasses 'see' the emitter when people are looking at the screen.
if it's setup like this and the Vizard image is flickering (i.e. showing left/right eye with active stereo) then the glasses will work and you will see 60Hz stereo (if the projector is run with 120Hz).
hope that helps!
Old 05-21-2008, 08:32 PM
Red face yeah ?
ok... this is exactly how it is installed in the lab... but I'm still loosing synch. !!
viz.FOREVER !!
D.
8800 ultra stereo driver Dave Vizard 21 10-25-2009 10:25 AM
anaglyphic stereo, backprojection & screendistance malte Vizard 4 02-23-2008 06:48 AM
Stereo eye separation ajmurray Vizard 4 10-24-2007 10:56 AM
quad buffered stereo? halley Vizard 2 10-19-2005 12:28 PM
SeeReal stereo with separate scenes Jerry Vizard 2 10-18-2005 12:02 PM
