Old 05-14-2008, 07:39 AM
south_bank south_bank is offline
Blending/Fading 5 Textures with a Slider
I'm trying to create an optional extras car showroom simulation which simulates for example, paint colour options. Rather than having lots of car geometry textured in many different colours and showing/hiding them according to which buttons are selected, I would like to use a slider control to fade/blend between the five different colour options of red, black, white, blue and green.
I have searched the example scripts and help files however the blend script seems only to support two textures. I have also experimented with fading between textures but due to relative inexperience, I'm struggling to find a solution with this method.
Is there another way around this issue that would allow me to control the car's paint colour through the five different colours with a slider , preferably of custom appearance? Any help and suggestions will be greatly appreciated.
Thanks.
Old 05-14-2008, 05:04 PM
Here is some sample code that should do what you want. It creates a class that allows to blend between an arbitrary number of values. The slider on the left will blend between 5 different colors and the slider on the right will blend between 5 different textures. Let me know if anything is unclear:
class MultiBlender(object):
	def __init__(self,values):
		"""Initialize blender with list of values"""
		self.values = values[:]
		self.dv = 1.0 / (len(values)-1)
	def getBlendValues(self,p):
		"""Returns begin,end, and percent value to blend between them, given total multiblend percent"""
		begin = int(p // self.dv)
		if begin < 0:
			return self.values[0],self.values[1],0.0
		elif begin >= (len(self.values)-1):
			return self.values[-2],self.values[-1],1.0
		return self.values[begin],self.values[begin+1],(p % self.dv) / self.dv
	def getInterpolatedValue(self,p):
		"""Return blended value at percent p, 0-1"""
		begin,end,p = self.getBlendValues(p)
		return vizmat.Interpolate(begin,end,p)
#Create quad and a blender that blends between 5 colors
colorQuad = viz.addTexQuad(pos=(-1,1.8,4))
colorBlender = MultiBlender([viz.RED,viz.BLACK,viz.WHITE,viz.BLUE,viz.GREEN])
#Add a slider for the blender
colorSlider = viz.addSlider(pos=(0.25,0.1,0))
def blendColor(pos,node,blender):
	node.color(blender.getInterpolatedValue(pos))
vizact.onslider(colorSlider,blendColor,colorQuad,colorBlender)
#Create quad and a blender that blends between 5 textures
textures = [
	'ball.jpg'
	,'brick.jpg'
	,'gb_noise.jpg'
	,'image2.jpg'
	,'lake3.jpg'
texQuad = viz.addTexQuad(pos=(1,1.8,4))
texBlender = MultiBlender([viz.addTexture(file) for file in textures])
texSlider = viz.addSlider(pos=(0.75,0.1,0))
def blendTexture(pos,node,blender):
	begin,end,p = blender.getBlendValues(pos)
	node.texture(begin,unit=0)
	node.texture(end,unit=1)
	node.texblend(p,unit=1)
vizact.onslider(texSlider,blendTexture,texQuad,texBlender)
Old 05-15-2008, 07:59 AM
Thanks for the rapid response, it's much appreciated . It all appears pretty clear on first glance and I think I won't have much trouble with it. Thanks again!
texblend or visible for multiple textures vizmaster Vizard 10 02-14-2007 03:50 PM
Textures not showing drahcir Vizard 1 08-15-2005 10:43 AM
number of textures to load lucalatini Vizard 2 05-12-2005 05:50 PM
Overlaying Textures with Alpha Masks vjosh Vizard 7 04-06-2005 07:46 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
