Old 07-31-2007, 02:24 PM
mjabon mjabon is offline
Another color question
I have a question about coloring. I want to just make a purple box so I wrote this:
#set up view
viz.clearcolor(viz.SKYBLUE)
view.translate(0,0,-25)
#add box
box = viz.add('box.wrl')
box.scale(3,3,3)
box.translate(0,0,0)
#color box
box.color(viz.PURPLE)
The thing is, looking straight at the box it appears white. Only when I move around in the world and look at different angles does it appear purple. Why is this? I want the box to always look purple from all sides.
Old 07-31-2007, 02:30 PM
It works fine for me here. Are you using the same box.wrl file that comes with Vizard or do you have your own box file?
Old 07-31-2007, 02:41 PM
no, it's the built in one....
Old 07-31-2007, 02:49 PM
I believe this might be a specular issue. Does adding the following command fix it:
box.specular(0,0,0)
The box.wrl file that comes with Vizard does not have any specular color, so your file might have been modified.
Old 07-31-2007, 03:04 PM
oh sorry, actually I had another spurious one in the folder. Now it works
