Old 07-31-2007, 01:10 PM
Vinicius Lima Vinicius Lima is offline
Colors
I was working with Vizard and I tried to change the color of some objects throught the script but I am not sure how to name some colors. Is there any link where I could find the way Vizard labels hues?
Vinicius
Old 07-31-2007, 01:56 PM
Vizard uses RGB to specify color values. Each component is specified with a value between 0 and 1. Here is a link to the Wikipedia page on RGB:
http://en.wikipedia.org/wiki/RGB
Old 07-31-2007, 01:58 PM
Thanks, I've figured that out already. My problem is that sometimes colors have names like SKYBLUE and I don't know how exactly the other RGB colors are called.
Old 07-31-2007, 02:31 PM
Vizard defines some common color values. Here are the names and values:
WHITE	= (1,1,1)
BLACK	= (0,0,0)
GRAY	= (0.5,0.5,0.5)
RED		= (1,0,0)
GREEN	= (0,1,0)
BLUE	= (0,0,1)
YELLOW	= (1,1,0)
ORANGE	= (1,0.5,0)
PURPLE	= (0.5,0,0.5)
SKYBLUE	= (0.5,0.5,1)
If you need another color then you will need to define it yourself.
Old 07-31-2007, 03:17 PM
Vinicius
Old 01-21-2017, 06:37 AM
tianmoran tianmoran is offline
Hi, I have a further question. How do I map a color in Vizard, like (0.5,0.5,0.5) gray, to a color represented by 8-bit? Is it (128,128,128) in the example?
Old 01-23-2017, 12:18 PM
Yes, the following code will apply that color to a box:
import vizshape
box = vizshape.addBox(pos=[0,1.8,4])
vizact.onkeydown(' ',box.color,[0.5,0.5,0.5])
You can press Alt + 1 in the Vizard editor to display a color dialog that inserts RGB values in the script for you.
Old 01-25-2017, 10:58 AM
That's very helpful. Thanks!
