Old 01-29-2010, 12:05 PM
llqqff llqqff is offline
How to split the body of vcc_male.cfg?
I am using the avatar vcc_male.cfg in VE. is there any way that I can split the body mesh to small meshes like arm, leg and so on? Thanks.
Old 01-30-2010, 09:49 AM
This is only possible if you own the Vizard Complete Character set which comes with the 3ds Max files for all the avatars included in there. If that is the case the procedure for doing this in Max would be:
-make selection sets for whatever you want separated from the initial mesh
-separate the parts out into multiple meshes, making sure they have the same skinning as the original mesh
-export each mesh onto the already exported skeleton
-add the meshes to the CFG file
split screen honey006 Vizard 3 05-21-2009 09:57 AM
Rigid body articulated human body models rfam Vizard 12 01-02-2009 04:00 PM
scaling avatar's body parts shai Vizard 4 03-03-2008 08:35 AM
separating heads from body for complete-characters.com vAlexia Vizard 0 09-18-2006 11:10 AM
problems adding a custom morph head to a custom body Greenwu Vizard 1 07-27-2006 10:32 AM
