where has my mouth_open file gone?
I am trying to get a script with the .vzf avatars running under 2.17a which was running under 2.16b.
when I load it, I get an error message saying "warning morph does not exist: mouth_open". So I looked at the .vzf files and there are open mouth morphs but they were generically named "morph". I've tried both renaming the correct morph as mouth_open and recreating the head and adding a new set of morphs with mouth_open as an option and nothing has worked. Any ideas? Thanks! |
When you load your vzf file into PeopleMaker does the "mouth_open" morph show up in the morph toolbar? |
It did not in the original head but I've added morphs from other heads and seen the new mouth_open file appear. This head would not work.
I also tried to renaming the morph from the original head in People Maker -- naming the open mouth morph "mouth_open" instead of "morph" as it used to be. Not sure if you can do this but I figured it was worth a try. Neither worked and now I am playing around with trying to create a new head and add new morphs. Any useful advice would be greatly appreciated! Rosanna |
Could you send me the vzf file so that I can take a look at it here? My address is lashkari@worldviz.com |
They are in your box now. Thanks so much!
