Unable to perform 360 rotation using vizact.spinto
I am trying to make an object perform a single spin action for 360 degrees followed by a forward motion. The following piece of code doesn't seem to help and the object just stays put. Code:
model = viz.add('object.ive') spinToYaw = vizact.spinto([0,1,0, 360], 50) moveForward = vizact.move([0,0,4], 5) model.addAction( spinToYaw ) model.addAction( moveForward ) Code:
spinToYaw = vizact.spinto([0,1,0, 180], 50) Any more than 180 degrees spins the object in the opposite direction: Code:
spinToYaw = vizact.spinto([0,1,0, 181], 50) To perform a 360 degree rotation, I thought i could get lucky if I run yaw actions two times using: Code:
spinToYaw = vizact.spinto([0,1,0, 180], 50) ... model.addAction( spinToYaw ) model.addAction( spinToYaw ) model.addAction( moveForward ) Code:
moveForward Code:
model.addAction( spinToYaw ) On the other hand, if I have a different axis for spinto as in the code below: Code:
spinToYaw = vizact.spinto([0,1,0, 180], 50) spinToRoll = vizact.spinto([0,0,1, 180], 50) ... model.addAction( spinToYaw ) model.addAction( spinToRoll ) model.addAction( moveForward ) 1) I get a 180 degree yaw, followed by 180 degree roll and then forward movement. If this logic works, then shouldn't two 180 degree yaws work as a 360 degree rotation ? 2) If there is a reason why two 180 degree yaws will not equal to a 360 degree rotation, what do I need to do to obtain just one single 360 degree rotation followed by another action. I do not want to use viz.FOREVER because it will keep on spinning the model. Thanks, Vijay. |
The vizact.spinto action will take the shortest path to reach the target orientation. If you are turning 360 degrees, then the shortest path is to do nothing.
Instead, use the vizact.spin action and calculate the duration and speed so the end result is 360 degrees ( speed * duration = 360 ). |
Thanks farshizzo. That was what I was looking for.
tracking head rotation orientation | VAmanda | Vizard | 3 | 09-21-2005 04:57 PM |
Weird lagging/choppiness when avatars perform actions | vjonshih | Vizard | 8 | 11-30-2004 04:08 PM |
getting absolute rotation | tavaksai | Vizard | 1 | 08-03-2004 01:40 PM |
