OSG version number in Vizard 3.0
Does anyone know what version of OSG does Vizard 3.0 use?
I am trying to load an .ive file converted from 3DS using OSG 2.8 and Vizard complains that the .ive file is new and is not supported by Vizard. Thanks, Vijay. |
Vizard 3.0 uses OSG 1.2. This means IVE files generated using newer versions of OSG will not load in Vizard 3.0, since IVE is a binary format. However, the OSG format should be backward compatible with older versions of OSG.
Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 11:13 AM |
Vizard tech tip: Text to Speech | Jeff | Vizard | 1 | 01-15-2009 09:39 PM |
Problems with newest version of Vizard | mjabon | Vizard | 6 | 07-29-2008 10:51 AM |
Next version of Vizard | bailenson | Vizard | 1 | 08-04-2004 05:45 PM |
number of faces to load using the 'old' txt version of avatars | bailenson | Vizard | 1 | 06-06-2004 12:30 PM |
